Author Topic: My '72 B5 'cuda Project  (Read 85761 times)
Offline brianz426
Re: My '72 B5 'cuda Project
« Reply #105 on: December 21, 2009 - 10:48:07 PM »
Wow you are making great progress, keep going.
Thanks for the updates.
Offline 'cudaCruiser
    • My '72 B5 'cuda
« Reply #106 on: April 17, 2010 - 10:03:12 AM »
Drivers quarter patches are in. I hope I didn't make too much of a mess of it. Definitely gonna be relying on Bondo to finish it out.
I found something behind the dash I didn't see before. I guess that'll be the next repair.
Then I'll work on this...
Does anyone have this part? Is it a part of the drip rail? I'm really not happy with what I did to the other side...
Mickey
"The man who complains about the way the ball bounces is likely to be the one who dropped it." Lou Holtz
Offline bandt
« Reply #107 on: April 17, 2010 - 04:17:50 PM »
Just found this thread, your doing a great job.
To minimize panel warpage try this. Once you have the fit you want, tighter the better. Tack the entire seam. Weld about a inch at a time then using an air gun blow on the weld until it is cool to the touch. Do this process until the area is done. This will almost eliminate warping. Its time consuming but you will be happy with the end result.
Brian
    • My '72 B5 'cuda
« Reply #108 on: April 17, 2010 - 09:26:21 PM »
I took my time with the stitch welds letting them cool to the touch before moving along.
It actually took me two days to weld it in with all the other things I've got going on around here.
The problem with this panel was it just didn't have the right contour for some reason.
Half the seam from the rear to the middle lined up great. No problems there.
The half from the wheel well to the middle didn't. That eight inches or so of seam will need maybe an 1/8" of
Bondo build up a couple of inches wide.
Mickey
Offline 70burntorangeT/A
« Reply #109 on: April 18, 2010 - 01:56:27 AM »
My challenger lower quarter patch didnt fit at all either...dont worry though, if you spend some time working it over with bondo you will never see it. My dad worked mine over and i cant see any imperfections in it at all and i even know where to look.
as far as the bottom part of the drip rail, im pretty sure i have a piece you could use for patches, but its from a challenger.
66 f-100 black  240 straight 6  3 on the tree.....currently blown up :(
70 challenger burnt orange 440 727 3:23-weekend cruizer
    • My '72 B5 'cuda
« Reply #110 on: April 18, 2010 - 11:30:59 AM »
So that is what you get when you order the drip rail kit? I'll order the drip rail kit if it includes that rusted out part.
Mickey
« Reply #111 on: April 18, 2010 - 12:17:43 PM »
I have a used section from a 74 challenger i cut up, i dont know if its rusted out or not i would have to look. If it have it then you can have it for free, just pay shipping. It is back in Arkansas, i am in Colorado. I am going back to Arkansas at the end of May. If you dont want to wait that long on a piece i may or may not have i understand.
Offline Challenger III
« Reply #112 on: April 19, 2010 - 08:10:04 PM »
 :wave: Nice job on the quarter patch.  :thumbsup: That is your roof structure that is rusted. the drip rail is just that .... the rail that the top welds to.
here's the roof structure before the rail is on (Challenger)
Here's the rail welded to the structure.
Then the top welds to the rails
Hope this helps!
« Last Edit: April 19, 2010 - 08:11:56 PM by Challenger III »
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
    • My '72 B5 'cuda
« Reply #113 on: April 19, 2010 - 10:31:26 PM »
Yeah it does help. So I guess I'll have to improvise...?
Thanks
Mickey
    • My '72 B5 'cuda
« Reply #114 on: April 23, 2010 - 11:04:34 PM »
Patched the hole in the cowl...
...and the rocker panel.
Inner fender battery tray location will be next.
Mickey
    • My '72 B5 'cuda
« Reply #115 on: August 03, 2010 - 08:43:38 AM »
Back to work!
Cut out the rust...
...replace with new!
I'm happy with it.
Firewall behind the brake booster next.
Mickey
    • My '72 B5 'cuda
« Reply #116 on: August 03, 2010 - 08:54:35 PM »
Patched the firewall...
...the hole behind the dash...
...and the battery tray location on the inner fender.
That takes me all the way around the car. Next I guess I'll turn her on her side and clean up the bottom side
so I can get the rear end and front end back under the car and get her back on her wheels.
Mickey
    • My '72 B5 'cuda
« Reply #117 on: August 07, 2010 - 11:03:29 AM »
Turned her sideways and spent hours with a wire brush on my drill.
The areas that have been soaked in transmission fluid or motor oil comes off easily.
So I will probably leave the factory under coating that is still adhering and just clean up and re-coat the
areas that need it. I can reach most of the under side with the drill and brush, but I'm thinking of getting
one of those cheap Harbor Freight spot blasters to get up into the corners and crevices.
Mickey
« Reply #118 on: August 07, 2010 - 01:27:50 PM »
Great patch work! You have convinced me on the rotisserie thing. I'm going nuts working under the car, my eyes are full of junk... even with goggles / faceshield!  :pullinghair:
    • My '72 B5 'cuda
« Reply #119 on: August 07, 2010 - 01:34:16 PM »
That's exactly why I have mine on a rotisserie.
 ;D
Mickey
