Author Topic: My '72 B5 'cuda Project  (Read 85752 times)
Offline 'cudaCruiser
    • My '72 B5 'cuda
Re: My '72 B5 'cuda Project
« Reply #90 on: May 05, 2009 - 10:08:03 PM »
So I figured the tail light panel was ready to weld in place.
But why is there such a huge space between the tail light panel and the deck lid?
I can put my fingers between there!
Does this look right? I don't have anything to compare it with.
Mickey
"The man who complains about the way the ball bounces is likely to be the one who dropped it." Lou Holtz
Offline ShelbyDogg
« Reply #91 on: May 06, 2009 - 12:06:50 AM »
Yes, that is right.You are just looking too closely at it. Make sure that it is even all the way across, then weld it up.
« Last Edit: May 06, 2009 - 07:46:48 AM by ShelbyDogg »
Offline AARudy
  • 1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
« Reply #92 on: May 07, 2009 - 12:04:18 AM »
Looking great! And I love the color!..... good work!   :thumbsup:
    • My '72 B5 'cuda
« Reply #93 on: May 15, 2009 - 05:53:11 PM »
The tail light panel is welded in.
All that's left is to weld in the tail light buckets and I can move to the drivers side quarters.
« Last Edit: May 15, 2009 - 06:27:03 PM by 'cudaCruiser »
Mickey
    • My '72 B5 'cuda
« Reply #94 on: May 20, 2009 - 11:43:03 PM »
So Harbor Freight didn't have the same trailer jack that I used for the front end rotisserie,
so I moved it to the back...
...and used a substitute for the front.
It ain't pretty but it does what I wanted it to do.
But before I start cleaning up the bottom side I'll probably repair the drivers quarter.
Mickey
Offline Chlngrcrzy
« Reply #95 on: May 21, 2009 - 12:40:12 AM »
 :2thumbs:Great idea with the trailer jacks. I wish i had thought of that with my homemade rottisserie.
    • My '72 B5 'cuda
« Reply #96 on: July 22, 2009 - 12:01:26 AM »
So I wasn't too happy with the way the rotisserie was working so I rebuilt it.
I'm much more confident in this one not falling apart.
So then I started cutting out the rot on the quarter. No surprises there.
I did however get a suprise when I looked up in the rocker panel...
...and found this tag. It says, "OK SAFETY ITEM". Anyone ever seen that before?
Mickey
    • My '72 B5 'cuda
« Reply #97 on: December 20, 2009 - 01:43:51 AM »
Finally got some more work done.
Rocker panel and small portion of wheel well patched.
Some tape for a template...
...scavenge some of the old quarter...
...tacked...
...and welded.
Mickey
    • My '72 B5 'cuda
« Reply #98 on: December 20, 2009 - 01:49:39 AM »
Cut out the worst part of the trunk extension.
Used it for a template.
And welded it in.
Next I'll fit in the quarter patch.
Mickey
Offline Glennster
« Reply #99 on: December 20, 2009 - 08:05:10 AM »
I'm just finishing up my project, we replaced the 7 1/4 rear with an 8 3/4, replaced the 318 with a stroked 340, and swapped the 904 for a 727. I really felt like I did something monumental until I saw this build.......
  My build was like doing an oil change compared to what you've done. You are doing a FANTASTIC job! ! ! ! !
You are amazing Sir!
It's really cool that your Son in involved, that too is GREAT!!!
Good luck, keep the hammer down!!!
    • My '72 B5 'cuda
« Reply #100 on: December 20, 2009 - 09:56:29 AM »
Thanks for the compliment. This stuff is not easy. I'd be much further along if I knew what I were doing.
Learning this stuff on the fly leaves a lot of room for improvement. I've had to redo almost everything I've done
on this car so far. Every time I move to another piece of work I learn something new. Trying to weld these panels
without leaving a wave seems impossible. That lower front quarter patch is the second one. I've got to get the
rear patch right the first time. This car was never intended to be a show car by no means. But it would be nice
to be a decent 10 footer. Heck, I'll settle for a car that doesn't fall apart going down the road.
 :thumbsup:
Mickey
Offline coupman35
  • It going to be FUN
« Reply #101 on: December 20, 2009 - 10:19:03 AM »
Nice work  look like t coning alon great keep it up  :thumbsup:
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Offline TKat13
  • Work In Progress...
    • Project Cuda
« Reply #102 on: December 20, 2009 - 11:49:55 PM »
That is incredible work! Very impressed and it even gave me an idea for my quarters.. thanks much
1974 'Cuda
2005 SRT-10 Ram
2006 Buell Firebolt XB12R (Murdered by person texting & driving)
2004 Mach 1
Offline Canadian Cuda
« Reply #103 on: December 21, 2009 - 01:37:06 AM »
i just found this thread and your doing great. :thumbsup: i'm at that same stage of cutting out rust. you are really coming along :grinyes:
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
Offline Kapteenikosmos
« Reply #104 on: December 21, 2009 - 07:35:02 AM »
 :thumbsup:
I know what you mean. I had about the same kind of work on mine as you are doing on yours and mine was also the first car I have ever welded on. Lot's of stuff got redone before I got it in primer.
I'm also building a driver and not a show queen so in my case I went pretty freely with bondo to get the lines back where they should be. Hopefully the bondo will last, atleast all the rust is gone.
Still, great work!  :cheers:
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
