Author Topic: Mopar Performance Electronic Distributor Vacuum Advance Adjustment  (Read 5555 times)
Offline wally426ci
    • maryland mopars
« on: September 11, 2007 - 02:12:19 PM »
 :dunno:
any help? Ive never adjusted this. which direction for what result?
when im at cruise speed the engine sort of sputters a little. i assume this is b/c of the timing at that point but i suppose it could be something else? maybe a condition of hotter cams?
im @ total time (35) running a 750 edelbrock.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Mopar Performance Electronic Distributor Vacuum Advance Adjustment
« Reply #1 on: September 11, 2007 - 05:28:13 PM »
If you are fine when you give it gas, then feel a miss when you level off in speed, then you are getting too much advance. Take the rubber hose off the vacuum advance pod. You can use a small Allen head key to adjust the advance inside the pod. Counter-clock-wise to retard it. I had to go 1 full rotation, but you can play with it.
Offline wally426ci
    • maryland mopars
« Reply #2 on: September 11, 2007 - 06:31:43 PM »
Excellent :2thumbs: Thanks!! I'll report back with an update.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline BB73Challenger
« Reply #3 on: September 11, 2007 - 06:33:46 PM »
I too made a change in distributor and had the same effect -
Best thing I did no kidding, I run no vacuum advance.
Advice given to me here from the all knowing Chryco - I've never had to go back.
I believe he has a permanent post on this including what the best timing is.
Jeff from Cleveland, Ohio
« Reply #4 on: September 11, 2007 - 06:57:40 PM »
Hey Jeff,  :wave:
  Glad you woke up here.  :poopoke:
I was once not using the vacuum advance since it gave me trouble. I had 12.2 MPG on the hiway, but I recently went up to 13.3 when I finally got off my lazy butt and adjusted that setting right inside the pod. This is at 70-75MPH with a built 440, so I am incredibly happy.  :jumping:  :jumping:  :jumping:
« Reply #5 on: September 12, 2007 - 02:02:29 AM »
:dunno:
 sputtering at criuse is typical when the vacuum advance is overadvancing the timing , generally I set total timing at 36-38* with no vacuum advance & leave the vacuum unhooked
Offline wally426ci
    • maryland mopars
« Reply #6 on: September 12, 2007 - 11:31:03 AM »
thanks, but like dangerfield said, id like to get decent mileage as well.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #7 on: September 12, 2007 - 12:00:21 PM »
adjusting them this way sems to improve the milage as well
