Author Topic: crud in the cooling system  (Read 741 times)
Offline miketyler
    • www.miketyler.net
« on: September 11, 2007 - 08:39:37 PM »
Was pulling my old pump off to see this business growing on my timing cover. It cleaned up easy enough but what can I do to eliminate that from coming back when I seal it up?
I was experimenting with a more dilute 50/50 coolant solution. Maybe the water brought that on? I know we have hard water here but I cant figure it has that much to do with this.  :clueless:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Re: crud in the cooling system
« Reply #1 on: September 11, 2007 - 09:07:00 PM »
Looks to me to be good ole lime deposits...hard water.    Removal would require a cleaner/acid to be run thru the system but unless you use distilled water it will come right back.
I'd say not to worry about it.
Offline GoodysGotaCuda
« Reply #2 on: September 11, 2007 - 09:11:42 PM »
Use Distilled water  :iagree: I've had nothing but in my block/alum rad since the hot tanking  :jumping:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: September 11, 2007 - 11:20:30 PM »
Distilled!! :grinyes:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #4 on: September 12, 2007 - 02:07:09 AM »
Make sure you do not have voltage in the system as well , I assum the battery ground is attached to the engine with a separate pigtail to the rad wall for the headlights etc
