Author Topic: What intake manifold?  (Read 4419 times)
Offline MOPAR FANATIC
« on: September 12, 2007 - 11:20:10 AM »
 :clueless: Wondering what intake to run on my 71 340 chally.727 trans w/276 gears.plan on going to 3.55's though.running a mopar cam pt#p4120231 hyd 284/284 o/l 68 .484/484 v/l 0 cam c-line 108.what stall converter should i use also.and what cfm carb do you suggest for this combo?any more info needed???
edit/move to engine and go fast goodies please.oops!!!!  :banghead:
« Last Edit: September 12, 2007 - 11:22:40 AM by MOPAR FANATIC »
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
Re: What intake manifold?
« Reply #1 on: September 12, 2007 - 11:55:34 AM »
I would use a 700-750 carb , I prefer Holleys , such as the 82751 750 HP
there are a # of good intakes , LD340 if you can get one or Eddy RPM air gap
probaby a 2600-3000 stall
Offline matt63
« Reply #2 on: September 12, 2007 - 12:03:54 PM »
I'm certainly happy with my Eddy RPM Air Gap.
Matt in Edmonton
'68 Valiant
« Reply #3 on: September 12, 2007 - 12:22:35 PM »
 :thumbsup: thanks guys,chryco is the cast boat anchor any good cause i still have the original.i read some where that the flow on these was'nt the best or was that on a 440 eng.  :clueless: can't remember for sure.  :dunno: whats the LD340 intake?
« Reply #4 on: September 12, 2007 - 12:26:33 PM »
the factory cast intake is a good intake , the LD is an old eddy intake only available used now
Offline mrbill426
    • All Around Mopars
« Reply #5 on: September 12, 2007 - 12:29:57 PM »
Are the factory 340 cast iron intakes all the same from say '68 to '74?
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline bb71challenger
« Reply #6 on: September 12, 2007 - 03:15:43 PM »
The old eddy LD was a great intake.  I ran one in my old 70 340 lime 'Cuda. If memory serves it actually has a pentastar and chrysler part number cast into it. I filed off the Edelbrock logo and painted it engine color, it looked stock.
*Brett*
Offline mrbill426
    • All Around Mopars
« Reply #7 on: September 12, 2007 - 03:17:37 PM »
Do you know if the LD340 will work with factory A/C?
MOPAR or NO car!
« Reply #8 on: September 12, 2007 - 03:20:26 PM »
[/quote
I am almost positive it will. It is pretty much identical to the stock iron 340 intake with regards to appearance. My 'Cuda did not have air but it did seem to have all the bosses for compressor brackets and such.
*Brett*
Offline mrbill426
    • All Around Mopars
« Reply #9 on: September 12, 2007 - 03:29:33 PM »
Cool if it does :cooldancing:  We have decided to restore the car back to stock "appearance" for shows and such but I have an LD340 and if it accepts the factory A/C the car came with, well, I won't tell  :bigshades:  Unless there are hood clearance issues with that manifold, the factory air cleaner, and the hood insulation blanket.  :clueless:
:working:
MOPAR or NO car!
Offline go-fish
« Reply #10 on: September 12, 2007 - 04:41:45 PM »
From what I understand the LD4B (318) and the 340's LD340 were what was wanted when a fella bought a new 318 or 340 car and wanted to upgrade. "Period correct" intake upgrade more or less.
I wasn't even close to being thought of yet so maybe an old codger could verify that.
I have an LD4B that I was thinking about putting on a 340 but I'm sticking with my new Victor Jr. single plane for the 408". :)
Offline mrbill426
    • All Around Mopars
« Reply #11 on: September 12, 2007 - 04:49:52 PM »
I think you are right about that.  Far as I know though the aluminum highrise that Mopar installed on the 340 had a Mopar part number and a Pentastar cast into it instead of "Edelbrock LD340".  Not sure if that "upgrade" was compatable with an A/C car though.
MOPAR or NO car!
Offline Dustu
« Reply #12 on: September 12, 2007 - 07:58:46 PM »
I 've had a couple LD4B 's that had part no. and some did not.The frt. runner are just the opposite on the 4B and LD for some reason could be for ac?
Offline mrbill426
    • All Around Mopars
« Reply #13 on: September 12, 2007 - 10:07:53 PM »
Hmmmmm, not sure, I'll have to look at mine  ;)
MOPAR or NO car!
Offline go-fish
« Reply #14 on: September 12, 2007 - 10:17:35 PM »
Here's an LD4B. It has the Edelbrock PN# cast on it.
