Lost all electric power in the 'cuda
Author Topic: Lost all electric power in the 'cuda  (Read 4509 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: September 15, 2007 - 05:43:53 PM »
I have lost all electric power in the 'cuda. I have checked the fusible link that's on the starter relay. And it's good. And I can't seen any fuses broken in the fuse box. Where do I check next?
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: Lost all electric power in the 'cuda
« Reply #1 on: September 15, 2007 - 05:46:31 PM »
fusible link at the starter relay
Offline ChallengerHK
« Reply #2 on: September 15, 2007 - 05:52:40 PM »
When my fusible link finally went south it looked good and had continuity, but after checking everything else I replaced it anyway.  All problems disappeared at that point.  Well, OK, all electrical problems  :)
- Han Solo, Star Wars
« Reply #3 on: September 15, 2007 - 05:58:30 PM »
If it's not the link it could be  to be at the bulkhead connector
« Last Edit: September 15, 2007 - 06:01:58 PM by bullitt99 »
Offline widing'cuda
« Reply #4 on: September 15, 2007 - 06:13:22 PM »
Ok, I'll try and replace the fusible link. I have just replaced the starter to High Torque mini starter (Powermaster Mastertorque 9613). Will the fusible link hold up to 50amp?
« Last Edit: September 15, 2007 - 06:27:46 PM by widing'cuda »
Offline GoodysGotaCuda
« Reply #5 on: September 15, 2007 - 06:55:53 PM »
It only takes one strand left in that fusible link making contact to have 'continuity' or voltage on the other side. Its ability to power up something/let current run through it goes away however.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #6 on: September 15, 2007 - 07:47:46 PM »
The power for the starter doesnt go thru the fusable link.
Offline jeryst
« Reply #7 on: September 15, 2007 - 08:10:22 PM »
Did anything change between the times when you did and didn't have power? Did you replace anything, do anything?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #8 on: September 15, 2007 - 08:13:00 PM »
Check your connections at the ammeter.
Do it with the battery disconnected, so you don't short out up in there with a wrench.
Tom
Tom
Offline matt63
« Reply #9 on: September 15, 2007 - 08:25:46 PM »
I'd be suspicious of the bulkhead connection too.  They are really marginal for the amp load.
Matt in Edmonton
'68 Valiant
Offline widing'cuda
« Reply #10 on: September 16, 2007 - 04:48:04 AM »
Yes I replaced the starter. When I turned the key to crank the engine I lost all power.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #11 on: September 16, 2007 - 05:07:58 AM »
Your + or -   on the batteri...!
Offline widing'cuda
« Reply #12 on: September 16, 2007 - 06:37:08 AM »
Found the problem. The cable from the battery to the starter had burned off. it was to thin (not the stock one that was there). So I added a larger cable and everything now works. Thanks for the tips guys!
Offline 71bigblock
    • Steve's Mopars
« Reply #13 on: September 16, 2007 - 10:04:36 PM »
Its always good to solve the problem.  Good to hear.   :2thumbs:
