Author Topic: steering column removal  (Read 1897 times)
Offline charger01
« on: September 15, 2007 - 06:12:06 PM »
Trying to remove mine from my 74 cuda.  it wont come out of the steering box.  am I missing something.  Also is there a way to remove the dash without destroying your windshield?
Offline GoodysGotaCuda
Re: steering column removal
« Reply #1 on: September 15, 2007 - 06:56:22 PM »
Did you knock out the pin that holds the column to the steering box?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline charger01
« Reply #2 on: September 15, 2007 - 07:37:43 PM »
No, Looks like one side is indented and the other side sticks out a bit.  can i just drive it out with a punch?  is that how you do it?
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #3 on: September 15, 2007 - 07:56:12 PM »
yup
« Reply #4 on: September 15, 2007 - 07:56:19 PM »
Yep, thats a must to come out.
1976 Dodge Warlock
Offline charger01
« Reply #5 on: September 15, 2007 - 09:14:41 PM »
does it matter which side i drive it from?
Offline matt63
« Reply #6 on: September 15, 2007 - 09:31:47 PM »
It shouldn't as it's a straight roll pin.  If one side is mushroomed go the other way.  I can't remember the details about removing the dash but I think you can get at the screws in the vents with a right angle type phillips screwdriver.  It might be a b*tch though.
Matt in Edmonton
'68 Valiant
Offline charger01
« Reply #7 on: September 15, 2007 - 09:49:21 PM »
Thank you gentlemen.  I will try to get it out tomorrow.  Dash came out easy with the windshield removed.  I couldnt get to the bolts otherwise.
« Reply #8 on: September 16, 2007 - 12:16:37 PM »
the pin can be driven out from either side , I use a tie rod pickle fork to pry the couple up off the steering box
Offline 71chmark
« Reply #9 on: September 16, 2007 - 12:24:19 PM »
I just unbolted mine from the firewall and pulled it out. The coupling and the pin stayed with the gearbox.  Just make sure you don't lose the two metal things and the spring clip.
I may be schizophrenic,
Offline charger01
« Reply #10 on: September 16, 2007 - 06:53:57 PM »
Ok, I got the pin out but the column still wont come out of the steering box.  It is free everywhere else.  Any ideas?
Offline matt63
« Reply #11 on: September 16, 2007 - 08:03:19 PM »
The coupling will slide off the splines with some prying.  I'm assuming the 3 bolts on the plate inside of the firewall near the pedals are out and the 2 bolts under column near the dash are also off and the harnesses are disconnected at the bottom of the column.
Matt in Edmonton
'68 Valiant
Offline charger01
« Reply #12 on: September 16, 2007 - 09:35:34 PM »
Yep everything is unhooked.  hung up on the spline and i cant get it off.  Tried a crowbar.  If it is this hard to come off , dont know how I will reinstall it.  Still cant get the darn thing off the steering box.
Offline tumbob
« Reply #13 on: September 25, 2007 - 12:52:26 AM »
I am putting mine together to put in and there is the large roll pin that fits the bottom box with the streering motor and a very small one at the top of of the coupling box that  holds the grease, gasket and shoes.... maybe leave the coupler on and on and take out the small pin out, it should come off with some prying.
09 Challenger SE
68 Charger 383
70 Challenger Convertible 340
72 Cuda 340
