no, i hooked to the small port at the back of the carb. Vacuum advance is in the front of the carb. i havent hooked into the brake booster because i do not have a big enough vacuum hose to tap in there and hook to the guage. from where i hooked up on the carb, i only have 1" vacuum at idle. when reved it goes up to about 15". the port is the one that you hook the vacuum hose to for the air cleaner snorkels
