Author Topic: Horn won't work-tried direct power too  (Read 912 times)
Offline Mike71Cuda
« on: September 16, 2007 - 05:14:39 PM »
No wthat I got the Hemi up and running I am tending to smaller issues. The horns won't work. I have put direct power from battery and still nothing. Is there anythging else to check on actual horns to determine whether they are good or not?
Smitty
Re: Horn won't work-tried direct power too
« Reply #1 on: September 16, 2007 - 05:46:59 PM »
IF they are properly connected to ground, and IF you run a wire from the "+" side of the battery, to their terminal(s), and nothing happens, then the horns are dead.  Have you checked each horn? Hard to believe they are both dead, but maybe.  :dunno:
Offline Mike71Cuda
« Reply #2 on: September 16, 2007 - 06:51:32 PM »
MEK
That is exactly what I did and no beep!
Checked both horns, in fact removed them scuff down to ensure ground, grounded each one and put powwer to them, no dice! ANy other tricks, seems pretty straight forward.
SMitty
Offline Oldschool
  • Member Since 9-05-06
« Reply #3 on: September 16, 2007 - 06:56:09 PM »
Stoopid question here......   Was the battery fully charged and were the wires used to test the horns solid?    :dunno:    I'm with Mikey here, kinda weird for both of them to be dead at the same time....    :clueless:   :1zhelp:
Ken  --  In Georgia
Offline GoodysGotaCuda
« Reply #4 on: September 16, 2007 - 06:56:21 PM »
MEK
SMitty
Dead horns  :2cents:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Oldschool
« Reply #5 on: September 16, 2007 - 07:16:57 PM »
One last suggestion before you throw em in the trash pile.  There is an adjusting screw near the center of the diaphram that vibrates that adjusts the pitch of the horn.  If it is too tight, or too loose---no beep.  Check that before you bury them forever......     :thumbsup:
Ken  --  In Georgia
Offline Ross
« Reply #6 on: September 27, 2007 - 12:57:53 AM »
Hit them with a rubber hammer.
I had one horn stick. It worked well after that.
'70 340 Challenger
A whole lot of rust and very little time to work on it...
