Author Topic: 340/ 650 too small???  (Read 9098 times)
Offline Pentastar Pete
« on: September 16, 2007 - 10:27:22 PM »
I have a 73 Challenger 340. bored .60 over. Stock heads, 484 lift cam, stock mopar ign. / silver box. 727 auto trans w/ shift kit.  Rear: 3.91 sure grip.
I have a Demon 650 carb.
In the 1/4, my best time is 14.2 at 95mph w/ both street and slicks.
I thought it should in the 13's..... Some guys are saying it's unde-carbed...
Any ideas????
Thanks
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
sleepychallenger
Re: 340/ 650 too small???
« Reply #1 on: September 16, 2007 - 10:35:24 PM »
interesting, my 383 is running a 625 CFM and seems to run really well with that size carb
« Reply #2 on: September 17, 2007 - 12:22:56 AM »
yes it is too small IMO , the later 340s had a 750 TQ earlier had the 6 pack , this may not be the whole problem though , tuning could get you a long way
« Reply #3 on: September 17, 2007 - 10:17:25 PM »
Thats what I thought... But I wanted to hear it from the pro's...
Thanks for the input......
68 Charger RT
Offline GoodysGotaCuda
« Reply #4 on: September 20, 2007 - 09:21:06 PM »
Any ideas????
Thanks
I have a 318 with a 650 avs carb, about same cam, stock 360 j-heads, +.030, same ratio and a 3500stall. I've ran a 14.0 was my best, i have a feeling i need more as well.. :banghead:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #5 on: September 21, 2007 - 10:34:44 PM »
As soon as I get some $$$$,  I'm going for the 750..... Then I'll be test running it at Island. But, that won't happen until spring.....
Hey, GGC, If you get the carb before I do, let me know how you like it....
Thanks.............
 :wavingflag:
68 Charger RT
Alice
« Reply #6 on: December 23, 2008 - 07:09:57 PM »
Seriously I'd stick with the 650 and work with the tuning. What demon is it... road, speed or mighty? I have a similar combo that loves it's 650 mech secondaries.
 I have heard of issues with plugged internal passages with demon carbs causing problems.
« Reply #7 on: December 23, 2008 - 07:15:11 PM »
Ya brought this thread back from September 2007  :drunk: :faint:
1976 Dodge Warlock
Alice
« Reply #8 on: December 23, 2008 - 08:39:00 PM »
well, it was a good year. Shall I pour you a glass?
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #9 on: December 24, 2008 - 02:02:23 PM »
Properly tuned 650 demon with camshaft under .500 lift cam will be enough with those stock heads. Make sure everything else is right before you change the carb.
I have run my 360 (0.060 over) with 600cfm holley vacuum pretty well. 13.8s 1/4mile 3330lbs car 3.23 rear end 727 trans. I have about 0.500lift, stock j-heads with stiffer valve springs. air gap intake.
Offline moper
« Reply #10 on: December 26, 2008 - 03:02:53 PM »
BG uses wet flowed ratings... If it were tested apples to apples with the 750 Holley HP (which is dry flow tested) it would flow closer to 730cfm. The MP 484 needs decent static compression to run really well, and it sounds like you have no stall convertor... With a 28" tire and 3.91s, the engine may feel sluggish. I think the carb is fine. Bigger one will only slow it down. but I agree it should be faster. I'd say get a cylider pressure reading to seee if the engine is doing what it should. (I know, old thread, but the i figured I'd answer it anyway...lol :bigsmile:
Offline 71chally416
    • The Streetwalker
« Reply #11 on: December 26, 2008 - 05:01:24 PM »
What kind of 60 ft time does it do?
