Author Topic: Update on sloow progress on 70 Challenger - Updated 12-9-2014  (Read 21702 times)
Offline MJS73
    • Mike's 1973 Challenger
Re: Update on sloow progress on 70 Challenger - Updated 9-14-08
« Reply #30 on: September 14, 2008 - 06:18:56 PM »
Not to change the subject, but you really should drywall your walls and and fire-tape the seams.  If you read the warning on the insulation facing you'll see that it says not to leave it exposed.  The paper vapor barrier is very flammable and it's going to burn if a spark hits it.
www.mikes73.com
Offline farmertan
« Reply #31 on: September 14, 2008 - 08:29:21 PM »
beautiful work so far i can only dream of my car being as far as yours keep the progress reports coming thank you
73 340 4sp 2nd owner since 85    brett
Offline ksierens
    • 70 Challenger Resurrection
« Reply #32 on: September 15, 2008 - 09:29:55 AM »
Thanks, I had planned on doing this.  I had to have a new garage built because my old one's foundation was sinking at one corner (built on clay) The new one has 18" wide foundation, 42" deep with rebar throughout, guess what, the same corner is sinking again.  :hyper:  When it gets hot, and dry, the water table under the clay drys out, and the clay drops. In the winter it usually comes back to level.  That being said, I was planning on drywalling it, but with the movement, I will have to look into something else for the walls.  I friend of mine who does siding work said he covered his walls in soffet material, which can be washed down.  I may consider doing that so it will move with the garage.
Kurt - SE Michigan
Offline ksierens
« Reply #33 on: September 21, 2008 - 06:05:13 PM »
Little more today, got the inside painted with Trim Black.  That is going to be it for a while, with a kid in college, not much extra money for now, but I will start buying the brake and gas lines and the emergency brake cables, before I start putting the rear end back in. I can also start on some of the other parts that need to be painted.
Kurt - SE Michigan
Offline ksierens
Finally got it back on the ground, here are some shots ....
Kurt - SE Michigan
Offline wally426ci
    • maryland mopars
 :clapping:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline usraptr
Very nice!!  :2thumbs: Hopefully mine will be catching up with you in the not to distant future.
(Edited 8-1-17)
Offline MoparCar
Re: Update on sloow progress on 70 Challenger - Back on the ground! Updated 12-2
« Reply #37 on: December 27, 2009 - 09:24:10 PM »
Looking Great!! Keep it going.
Wes
Offline DAYLEY/CHALLENGER
Slow cooking gets the job done too................ :2thumbs: :2thumbs:
Dave or David
Offline 70shaker6pk
Looking really good!!
'JS23V0B'  1970 Challenger R/T N96 440 Six Pack
 :2thumbs:
« Last Edit: December 28, 2009 - 05:47:50 PM by Moparal »
Offline ksierens
Errr, what Al?
Kurt - SE Michigan
I responded to the first page post, then noticed I didnt see page 2 or 3.  So I deleted what I said...I'm workin on 2 computers as I read the posts right now :wave:  sorry
Offline IMNCARN82
  • LeDZeP
« Reply #43 on: December 28, 2009 - 07:43:32 PM »
HEY! WoW that looks nice!  Keep doing a little every time you can. It will happen!!   If your looking for a good cheap wall board.Try FRP (?) It's the white fiberglass type of product used in food service n' public bathrooms.Screw it up.Has finishing/seam trims.You can hose it right down,No paint ever. And it will slide around a bit in the channels.Just a thought.  I've been muddn' drywall all day. Could do it in my sleep. :eek4:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline ksierens
Thanks for the tip, I will check it out!
Kurt - SE Michigan
