Helped a buddy put some new spring perches on the back of his 88 Ranger last night, he had a "flip kit" for using a truck rear end (that mounts under the spring) mounted above the spring but the pinion angle was all messed up. like 15 degrees nose up messed up. We did a 2.3L turbo T5 trans swap on this truck a few years ago and recently set it up for a T3/T4 hybrid with a ford powerstroke intercooler, gutted upper intake, knifed (profiled) lower intake, flipped exhaust manifold (aftermarket) 42lb/hr injectors and bigger VAM sensor. Finally should get this thing on the chassis dyno saturday. Hoping for about 210 at the wheels with the stock computer map, timing and boost. I don't think we will get a chance to mess with it at the dyno but it will be good to get a baseline to start tuning. Oh yeah, and this is smog legal - in California even.
