Author Topic: Willow Springs, Spring Fling, MATS 1600 mile road trip  (Read 193324 times)
Offline miketyler
    • www.miketyler.net
Re: ntstlgl 1970 - engine is in
« Reply #465 on: January 03, 2010 - 09:26:40 AM »
your TIG work rocks - looks like fine stitching!   :smokin:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline the_engineers
« Reply #466 on: January 06, 2010 - 06:40:00 PM »
Is there a rule of thumb on how to set the injector bung height?  I've got my bungs, rails and injectors, but haven't drilled the intake yet.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline ShelbyDogg
« Reply #467 on: January 06, 2010 - 06:51:25 PM »
Brooks,
When I had mine welded in, the bottoms of the bungs hung into the runner. When I cleaned them up with a die grinder, so much material was remove that it almost got to the area where the o-ring has to seal on it's sides. If I knew it would have done that, I would have had them up a little higher.  Think about this when measuring.
Offline Tubbed440
  • Suspension NinJa
« Reply #468 on: January 06, 2010 - 08:01:57 PM »
Brooks,
I ran into the same issue.  You can see what I did on the bottom of this page and continued on page 7.
http://www.cuda-challenger.com/cc/index.php?topic=27484.75
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Offline ntstlgl1970
  • T a c o c a t
« Reply #469 on: January 15, 2010 - 04:48:54 PM »
This was the same reason I had to redo mine, I made the installed height of the insert too short and it broke through. After putting the tank in the car, with a -10 adapter in the tank and a 90 degree fitting, the clearance to the differential was/is too close. I ended up adding a fitting to the side of the sump in the rear and will have to plug the fittings on the front of the sump. Oh well. I thought there would be more clearance than that but things happen. Anyway with the long weekend, I'm hoping to get most of the fuel system stuff finished so I can undercoat/paint the back end of the car.
« Last Edit: January 15, 2010 - 04:53:10 PM by ntstlgl1970 »
Offline ntstlgl1970
  • T a c o c a t
« Reply #470 on: February 22, 2010 - 03:40:29 PM »
Got the rear underside of the car undercoated (bedliner stuff) that was a messy experience. came out pretty nice. Have to do the inside of the trunk next.
Offline Travis72
« Reply #471 on: February 22, 2010 - 10:53:06 PM »
Looks good!  What bedliner was that?
Travis
72 Cuda
Offline ntstlgl1970
  • T a c o c a t
« Reply #472 on: February 23, 2010 - 01:41:27 AM »
Shake and shoot from dominion sure seal. I used their tintable version last night for inside the trunk. Did the underside and inside the trunk in the last 3 days, I'm pretty happy with the results.
« Last Edit: February 23, 2010 - 04:23:06 PM by ntstlgl1970 »
Offline Tubbed440
  • Suspension NinJa
Re: some progress
« Reply #473 on: February 23, 2010 - 05:13:22 PM »
Dang that thing looks good.  Keep up the good work!  :thumbsup:
74 Dodge Challenger
(work in progress)
Offline ntstlgl1970
  • T a c o c a t
Re: some progress
« Reply #474 on: February 23, 2010 - 07:55:25 PM »
Thanks, seeing Conv340's car running and driving got me motivated a bit more to work on it. Guess that is a good thing.
Re: some progress
« Reply #475 on: February 23, 2010 - 08:05:50 PM »
I like the way the bedliner stuff worked out.  :2thumbs: I know what I'm going to use on mine now.
Offline Tubbed440
  • Suspension NinJa
Re: some progress
« Reply #476 on: February 23, 2010 - 09:32:25 PM »
Yea, I know what you mean.  It seems like the mountain of stuff that I have left to do the car is higher than Everest. Seeing everyone's progress helps keep me motivated too.  :grinyes:
74 Dodge Challenger
(work in progress)
Offline wally426ci
    • maryland mopars
Re: some progress
« Reply #477 on: February 24, 2010 - 11:47:57 AM »
What do you ad to tint the bedliner for color? looks awesome!  :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline ntstlgl1970
  • T a c o c a t
Re: some progress
« Reply #478 on: February 24, 2010 - 02:41:22 PM »
The tintable bedliner uses the same paint that you use on the car, minus the "binder" and reactive reducer components (basically just the color itself). It makes the liner more expensive since you need about a 12 ounces of color to tint each of the containers of liner (4 per package, 3oz of color per quart of shootable liner). It should be pretty durable and give a little sound deadening.
Offline wally426ci
    • maryland mopars
Re: some progress
« Reply #479 on: February 24, 2010 - 03:45:49 PM »
I will be looking into that!
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
