Author Topic: Willow Springs, Spring Fling, MATS 1600 mile road trip  (Read 193351 times)
Offline ntstlgl1970
  • T a c o c a t
Re: 11/1 - edelbrock 440xt here....it runs - again...
« Reply #570 on: November 03, 2010 - 05:33:48 PM »
Putting in breather fittings is on the list of things to do. With the old valley pan, the breather fittings were part of it. Now I have to make a new one. At this point, the oil fill cap is the distributor plug...
« Reply #571 on: November 03, 2010 - 06:27:10 PM »
I kinda thought the distributor plug was the oil fill, but I couldn't see it. :2thumbs:
Offline ntstlgl1970
  • T a c o c a t
« Reply #572 on: November 05, 2010 - 12:31:39 AM »
Now with noise:
Re: 11/4 - edelbrock 440xt here....it runs again...short vid
« Reply #573 on: November 05, 2010 - 07:34:01 AM »
 :clapping: :woo: sure sounds good! That thing sounds like it's sucking a lot of air! :thumbsup:
Offline ShelbyDogg
« Reply #574 on: November 05, 2010 - 07:56:31 AM »
It is a lot more noisy that the video labeled "First run wue error"
Nice to have it running again.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #575 on: November 05, 2010 - 09:54:32 AM »
Looks and sounds great!  :thumbsup:
Offline sadil340
« Reply #576 on: November 05, 2010 - 11:59:52 AM »
Nice noise! :ylsuper:
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline Tubbed440
  • Suspension NinJa
« Reply #577 on: November 05, 2010 - 07:18:14 PM »
I'm officially jealous.  :grinyes:
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
« Reply #578 on: November 05, 2010 - 09:14:25 PM »
I gotta stop looking at this thread....It's gonna make me broke?  :smilielol: :drool:
Offline ShelbyDogg
« Reply #579 on: November 08, 2010 - 11:31:51 PM »
Here are the measurements for  the 413-440 ProFloXT
Offline ntstlgl1970
  • T a c o c a t
« Reply #580 on: January 03, 2011 - 11:16:25 PM »
It's been a busy holiday season, but I've got a few things done, the most visible being the MAF sensor and intake tube. Also got the throttle hooked up. I still have a bunch of wiring cleanup to do and I am redoing the exhaust. I messed up the spacing between the trans and the exhaust enough to where there wasn't enough room to hook up the shifter. Also scored a slap stick and I'm modifying that (what else is new) so I can hook it to the trans without the bellcrank assy. The edelbrock throttle body needs a different cable end to connect to it so I had to figure that out too. I started it up tonight with no exhaust to test out the throttle pedal - yeah it works.  :cheers:
Re: 1/3/11 crawling slowly towards something....
« Reply #581 on: January 04, 2011 - 08:19:49 AM »
 :drool:  That looks sweet! :clapping:
Offline ntstlgl1970
  • T a c o c a t
« Reply #582 on: April 12, 2011 - 02:54:03 AM »
Well, the intake hits the hood, not sure what I am going to do about that. Pretty much right where the throttle body attaches
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #583 on: April 22, 2011 - 02:53:55 PM »
that intake is sweet! can u machine that large ridge where it mounts down?
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline ntstlgl1970
  • T a c o c a t
« Reply #584 on: April 25, 2011 - 05:02:24 PM »
Unfortunately it is going to take more than just machining the one edge, I'm probably going to have to make a slot cut in the lower part of the scoop opening. Meanwhile I started putting some of the trim back on and some of the glass. I haven't had the stainless back on the drip rails since about 1987. It's nice to see it on there again, and the rear windows too...
« Last Edit: April 25, 2011 - 05:06:28 PM by ntstlgl1970 »
