Author Topic: 3rd member, which one to go for..???  (Read 3441 times)
Offline duodec
Re: 3rd member, which one to go for..???
« Reply #15 on: October 05, 2007 - 12:29:03 AM »
not only availablity but also the fact that the cone are throw away once they are worn where the clutch can be rebuilt indefinatly & are far stronger so they get a better resale price due to quality
 the True Track / Torson design are the best I have seen
I just really wish the Torsens now available didn't require Green bearings...
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #16 on: October 07, 2007 - 04:12:47 AM »
I want 3.23....!
It will prob. be easyer for me to find a 3.member with 3.23 without posi..
If I rebuild the posi I got in my 741, will it fit in to any - 742 / 489 drop out..???
« Reply #17 on: October 07, 2007 - 04:43:00 AM »
Yes , the Posi / sure grip will fit into any carrier
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #18 on: October 07, 2007 - 05:15:19 AM »
I think I read on some "rearend homepage", that ther could be a difference in numbers of splines on the axels, is that correct..???
« Reply #19 on: October 07, 2007 - 11:27:03 AM »
not with the 741/742 /489 , some of the diffs from the 50s could be different
Offline moper
« Reply #20 on: October 09, 2007 - 09:26:08 AM »
I saw someone mention somewhere that there was a spacer that could be bought so you could use the tapered bearings and adjusters. I havent seen one, but I'm sure it wouldnt be hard to make. Just hard to keep in place when an axle was pulled... There's nothing in the centersection to retain anything...lol.
Offline hemi71
« Reply #21 on: October 09, 2007 - 05:33:17 PM »
Use a little heavy weight grease on the spacer...holds it in there just fine. I've never seen one come out just by pulling an axle.
Nothing wrong with green bearings if you are driving it as a cruiser. Now if it's an everyday driver or you are going road racing, the original roller bearings will long outlive the ball bearing "green" bearings...they are good for about 30-35K miles from what I've seen.
