Author Topic: 3rd member, which one to go for..???  (Read 3446 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: September 19, 2007 - 06:00:46 PM »
At last I got a clear answer from Randy's ring and pinion.
But, - which one do you think I should go for, - or can it be done better/cheaper else where..???
Shouldent the 489 be the strongest..???  They got it as the cheapest..???
Is the Auburn like the original MoPar posi..???
We do not have 3.23 ratio for any of the casting numbers.  As you probably discovered the 3.23 ratio is very difficult to find.  The lowest ratio we have is 3.55 and goes higher from there.
 We do have the higher ratio 3rd members in stock.  Currently an 89 bolt in 3rd member is $1044.39 and comes with an Auburn posi while the 42 bolt in 3rd member is $1276.47 which also comes with an Auburn posi.  The 42 bolt-in with 355 and a Detroit Locker will run you $1276.47.
William Lapilio
Randy's Ring and Pinion
« Last Edit: September 19, 2007 - 06:12:43 PM by cowboy »
MoPar's for Cruizin, Racing & Pro-touring: www.CowboyCars.dk
1930 Plymouth Hot Rod wannabe - 1957 DeSoto Fireflite Sportsman - 1967 RaceCuda  -  1968 Barracuda  -  1971 Challenger R/T Conv.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 3rd member, which one to go for..???
« Reply #1 on: September 19, 2007 - 06:05:32 PM »
I'd go with the 89 and an auburn. The locker will make a ratcheting noise around corners.
1996 Dodge Viper GTS Coupe
Offline RaptorF229
  • A work in Progress
« Reply #2 on: September 19, 2007 - 11:11:23 PM »
Let me know what you end up going with and randy's service. I want to replace my 2.76s.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: September 20, 2007 - 05:29:56 PM »
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #4 on: September 22, 2007 - 03:47:53 PM »
 :popcorn:    :feedback:
Offline matt63
« Reply #5 on: September 22, 2007 - 05:28:25 PM »
posi is chebby terminology.   ;)Mopar differentials are referred to as Sure-grip. Two styles were available being the clutch and cone type.  The Auburn is the cone type.  I just bought a clutch type differential called the Dyna-Lok.  I think it's made by Dana.  I think they are on permanent back order right now through Yukon but I found one at a dealer.  Here is a website with info on the 8 3/4.
Matt in Edmonton
'68 Valiant
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #6 on: September 22, 2007 - 07:53:09 PM »
website???   :clueless:   :popcorn:
Offline matt63
« Reply #7 on: September 22, 2007 - 08:32:02 PM »
Matt in Edmonton
'68 Valiant
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #8 on: September 30, 2007 - 06:01:04 AM »
Can't I get a MoPar sure-grib any where..???
Offline matt63
« Reply #9 on: September 30, 2007 - 10:49:59 AM »
Matt in Edmonton
'68 Valiant
Offline HP2
« Reply #10 on: September 30, 2007 - 11:34:54 AM »
Yes. Auburn was one of the original suppliers to mopar.
Another place to shop for gears is Reider Racing; http://reiderracing.com/ I've always liked them better than Randy's.
Offline tactransman
« Reply #11 on: September 30, 2007 - 09:59:47 PM »
Terry-tactransman
Union, Mo.
Offline moper
« Reply #12 on: October 04, 2007 - 12:32:47 PM »
A street car, I like the Tru Trac. No clicks, positive locking, no clunks or tire squeals on corners. I've seen plenty of the new auburns get fried in a year or less with a little abuse. So I think I'd lean towards a clutch type remanned if I had to stay in factory stuff..
Offline RD
    • KANSAS MOPAR CRUISE
« Reply #13 on: October 04, 2007 - 03:14:29 PM »
i believe the price differential is due to the availability of the 489 in comparison to the 742.  The 489 case was produced in larger quantities, hence they can sell them at a lower price without worriment of replacing the case with difficulty.
Eskridge, Kansas (32 Miles SW of Topeka, KS)
« Reply #14 on: October 04, 2007 - 04:05:12 PM »
not only availablity but also the fact that the cone are throw away once they are worn where the clutch can be rebuilt indefinatly & are far stronger so they get a better resale price due to quality
 the True Track / Torson design are the best I have seen
