Author Topic: Question about the window-to-trunk drainage channels.  (Read 1657 times)
Offline willhaven
« on: September 19, 2007 - 06:38:09 PM »
You know, the ones that run from the rear window to the trunk channel. Are these necessary, do they actually function well to divert water from the rear window?
Since I'm doing a custom and I'm shaving door handles and signals, etc, I thought I'd have those channels filled in too.
Thoughts?
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Question about the window-to-trunk drainage channels.
« Reply #1 on: September 20, 2007 - 02:59:47 PM »
you mean the seam between the qtr panel and the filler (dutchmen) panel?
« Reply #2 on: September 20, 2007 - 04:15:27 PM »
I believe that's what he means. It's a common rust area.   :eek7:
Offline willhaven
« Reply #3 on: September 21, 2007 - 04:25:11 PM »
Yeah, the seam there. Is it necessary?
I'd like to eliminate it entirely.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #4 on: September 21, 2007 - 04:29:28 PM »
I don't think there is any useful reason for it.  They probably just filled it with caulk because bondo may crack with the body flexing.
Kurt - SE Michigan
« Reply #5 on: September 21, 2007 - 06:01:01 PM »
Offline willhaven
« Reply #6 on: September 21, 2007 - 06:15:13 PM »
So you should be able to just weld it and grind it smooth?
Offline DAYLEY/CHALLENGER
« Reply #7 on: September 21, 2007 - 10:55:01 PM »
I wondered about that area too.   Since it was where there was a panel joint, it was easier to manufacture without doing a weld job.   It would look nicer without the seam.
Dave or David
Offline willhaven
« Reply #8 on: September 22, 2007 - 08:03:45 PM »
Cool, I think I'll call my guys tomorrow and tell them to nix the seams. Thanks for the input.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #9 on: September 22, 2007 - 09:35:34 PM »
I told them to clean them out and they got filled, hope that it lasts.
Tom
Tom
Offline willhaven
« Reply #10 on: September 23, 2007 - 12:22:59 AM »
Hopefully they're thin enough to weld them in and grind them down. I don't know if I'd trust any kind of filler for the long haul.
