Challenger6pak,
I think I understand you correctly. Put the wing on, cut some tube stock to the distance between the bottom side of the trunk lid (inside) and the topside of the brace (side facing trunk lid). This allows you to tighten down the wing to the tube stock eliminating the pulling/denting effect of the wing on the trunk lid. I assume you have to drill the holes on the inner skin (not the outer skin) of the trunk to a larger diameter to accomodate the tube stock? Please let me know if I have correct? Thanks...a great idea!!! Ted
