Author Topic: Crate Hemi Timing  (Read 808 times)
Offline BIGSHCLUNK
Crate Hemi Timing
« on: September 21, 2007 - 10:22:36 PM »
I have never played with/checked Nikki's timing. Can anyone tell me the base timing for a basically stock Crate Hemi?  :dunno: I thoght I'd play a bit tomorrow and would like to know a good place to start. THANKS
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Crate Hemi Timing
« Reply #1 on: September 22, 2007 - 02:35:14 AM »
I would bring the rPM TO 3000 & ADVANCE THE TIMING until you can hear it pop in the exhaust & back it off until the rpm just starts to drop & lock it down there , typically you should end up around 16* at idle & 36 total as long as the vacuum advance is disconnected but who says your damper or indicater are right ?
Offline BIGSHCLUNK
« Reply #2 on: September 22, 2007 - 10:11:57 AM »
Thanks Neil, hope I can get it right the first time.  :dunno:  :2thumbs:
One question tho.... wouldnt it be easyier to set at 16* to start with and go from there?
« Last Edit: September 22, 2007 - 10:16:06 AM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: September 22, 2007 - 11:00:08 AM »
depends if the dist has 20* mechanical advance curve & if the timing marks are correct on your engine , if not you could be out to lunch
Offline BIGSHCLUNK
« Reply #4 on: September 24, 2007 - 08:01:31 AM »
Ok , I played "tuner" (dumba$$) this weekend. Cured one issue I had. But as my luck goes, still have another. Carb related maybe??? I seem to have a slight miss at 45MPH. Above that or below that no problem. Also a response delay on WOT from a standing start. Very respondsive when I'm under the hood/and in divability situations. Just a delayed reaction off the line so to speak on WOT. The adjustments on the pumps seems. Good response from pump shot in all other situations.
Also I didn't realize the difference in timeing between an oringinal (Friends 68) And newer crates (mines 01). I asked him  about his timing , his is TDC. Mine would barely run at that , but had to try it for the heck of it. Different cams I guess??
Anyway pardon my stupidity..... suggestion?? THANKS
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #5 on: September 24, 2007 - 10:58:41 AM »
have you checked the float level ?
Offline BIGSHCLUNK
« Reply #6 on: September 24, 2007 - 02:22:41 PM »
Yes I have, back when I replaced the power valve (leaky diaphram) in spring. Shes got under 1K miles since then.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
