Author Topic: fuel pressure problem  (Read 1929 times)
Offline todd383
  • I'm a llama!
« on: September 22, 2007 - 08:51:19 AM »
On my friends challenger, 383, mildly built, the problem here is the fuel pressure drops after about 25 minuters of driving, it has a complete new fuel system,from tank to carb, and upgraded to 3/8 line, it has a holley mech. pump, 120gph, and edelbrock regulater, when u first start it, it has 6 1/2 lbs. of press. then it slowly drops too 3lbs, this is not normal i hope :dunno: any body know what the problem might be , before i start changing parts :pullinghair:
Offline GoodysGotaCuda
Re: fuel pressure problem
« Reply #1 on: September 22, 2007 - 09:22:59 AM »
New fuel filter? What about tank sock, or any junk in the tank? Check for any remotely kinked rubber lines, because they get sucked on while running and can make that kink worse. Also tighten up all the clamps.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline matt63
« Reply #2 on: September 22, 2007 - 10:08:32 AM »
Maybe check the fuel pump grounding???
Matt in Edmonton
'68 Valiant
« Reply #3 on: September 22, 2007 - 10:09:32 AM »
Mech pump  :wave:
1976 Dodge Warlock
« Reply #4 on: September 22, 2007 - 10:14:30 AM »
Is the fuel tank vented good?  Will it do it with the gas cap off? Is the bowl vent open on the carb?
« Reply #5 on: September 22, 2007 - 10:47:21 AM »
I think all is well here.  :2cents:
I have a hi-volume mechanical fuel pump on my car. Without a regulator I would see 9-10 at start-up, then it would drop to around 7 after driving it around for a while. I put a regulator on it to keep it at a steady 6 now. It is about 8 at start-up now, but drops to 6. I would suggest turning your regulator up a tad, that way it won't drop below 5-6 pounds.
« Reply #6 on: September 22, 2007 - 11:01:32 AM »
as AL said if the tank is not vented well it could be locking up with vacuum
« Reply #7 on: September 22, 2007 - 11:04:27 AM »
True, you need the pressure differential to make that work  :clueless:
1976 Dodge Warlock
Offline matt63
« Reply #8 on: September 22, 2007 - 11:07:21 AM »
oops -forget that one.  I do like return lines on high flow pumps.
Matt in Edmonton
'68 Valiant
Offline todd383
  • I'm a llama!
« Reply #9 on: September 22, 2007 - 07:54:09 PM »
Everything is new, from tank to sending unit, high flow fuel filter, etc, etc, I have the same setup on my car and has no problems, but it does drop a little,  Thetank is vented, like i said, everything is NEW!!!!!!!!! when the car is cold, the pressure is 7lbs. and u can adjust it when the car is cold or running for a little bit, but when it is warmed up, after driving it for a little bit, it drops to 3 lbs. and when u try to adjust it, it does nothing :hyper:, the rubber lines i checked, no collapsing.And it does have a new carb, and we did  switch carbs for the hell of it and still the same.    AGAIN :pullinghair:
« Reply #10 on: September 22, 2007 - 08:06:00 PM »
You can drive with it 3 PSI, but that's scary low. I can't understand why adjusting the regulator does nothing, unless the problem is the fuel pump or further back. Do you have a new pushrod for the fuel pump installed in the block??  It could be a bad regulator too. If it were a plugged or kinked line, or no air getting into the tank, the pressure would eventually go to zero. I'm stumped.  :banghead:
Offline todd383
  • I'm a llama!
« Reply #11 on: September 22, 2007 - 08:43:40 PM »
Well,  i just got of the phone with my friend, what were gonna do is change the pump first, see what happens, and if that is not the problem , then change the regulater,and see what happens. :banghead:
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #12 on: September 22, 2007 - 08:44:54 PM »
Good luck on finding the problem   :2thumbs:
« Reply #13 on: September 23, 2007 - 02:37:01 AM »
check the fuel pump pushrod while the pump is off , both ends should be equal lenght
moparniac
« Reply #14 on: September 23, 2007 - 12:06:01 PM »
I had a brand new fuel pressure regulator that did nothing as well when adjusting it... I replaced the regulator and that solved the problem...
