Author Topic: Lower Control Arm Removal  (Read 1005 times)
Offline MR291
« on: September 23, 2007 - 09:44:31 PM »
I need to replace the lower control arms and torsion bars on the Cuda.  Other than removing the necessary bolts on the suspension to drop the control arms, do I need to use a torsion bar removal tool, or should they come loose once the control arms are removed.  Also, is there a left and right side torsion bar.  If so, are they marked L and R or is by by a part number.
Appreciate it.
Re: Lower Control Arm Removal
« Reply #1 on: September 23, 2007 - 10:32:38 PM »
remove the nut on the LCA pivot pin & the caster strut & the snap ring behind the bar & just pry the LCA & bar backwards , no removal tool nessisary for the T bar
 the bars have both L & R & the part # on them , odd is always left even is right
Offline MR291
« Reply #2 on: September 24, 2007 - 05:47:51 PM »
Perfect.
Thanks.
« Reply #3 on: September 25, 2007 - 03:17:42 AM »
 :2thumbs:
