« Reply #1 on: September 27, 2007 - 02:00:06 PM »
I can tell you that isn't the correct vacuum advance for that distributor. That's a CAS (Cleaner Air System) electric vacuum advance/retard from a 70/71 model with the wires cut off and the plastic cover removed. The tag does show as being from a 71, but I wasn't aware of any dual point distributors being made after the 60's. The only distributors I've seen with that vacuum advance had the aluminum single point distributor body. Maybe someone transferred the tag? I can provide the specs for the distributor, but I'm not sure if that is what you were looking for or just the application.
« Last Edit: September 27, 2007 - 02:12:33 PM by ntstlgl1970 »
Logged
