How hot does your car run?
Author Topic: How hot does your car run?  (Read 1801 times)
Offline RDF
  • The pain that greets me is the stick that beats me
« on: September 27, 2007 - 02:08:38 PM »
How ot does your car run?  I'm curious to know as I just installed new gauges in my car and I never had a number readout of my temp, just hot or cold.  I've noticed mines been running about 200-205...sometimes it gets close to 210, but not too often.  Is that temp ok?  :dunno:  I've got a 360 in my car with stock radiator and fan.  The heater core has been bypassed as well.
What's everyone else's running?
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline Mopar73340
Re: How hot does your car run?
« Reply #1 on: September 27, 2007 - 04:41:41 PM »
My 340's run 190-195* tops with 180* thermostat and the A/C on and in traffic. If on the road, they stay right where the thermostat opens 180-185*. Stock cooling system with clutch fan. If the cooling system is working properly it should not run above 200* for the most part. Is yours running over 200* in traffic or on the road?
Offline RDF
« Reply #2 on: September 27, 2007 - 05:03:55 PM »
Seems about 205-210 in traffic and 195ish running on the road.
Bob
1973 'Cuda
My build:
Offline GoodysGotaCuda
« Reply #3 on: September 27, 2007 - 05:12:04 PM »
180. All day. You may have a 195 t-stat in there Bob. Usually just starts opening around that temp. I run a 180 stat in my car with my helicopter electric fan lol.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Mopar73340
« Reply #4 on: September 27, 2007 - 08:29:12 PM »
 :iagree:  You may want to put a 180* stat in there for the summer if you are worried about the 210*.  If you have a 195 in there it would be good for winter.
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #5 on: September 27, 2007 - 08:31:42 PM »
Well i have a beecool rad and dual electric fans and my car runs 185-195 on the road and if in traffice for a bit goes up to 210-215 but i have a 195 thermostat and fans come on at 195.The idiot lite in the old dashes come on at 230 i asked a friend who works at a chrysler dealership since 1966 and he said as long as your undr 225 your ok.
« Reply #6 on: September 28, 2007 - 02:05:12 AM »
I agree , under 220 you are good , 205 in traffic is no issue at all
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #7 on: September 28, 2007 - 05:34:19 PM »
180 IS TOO  cold.
« Reply #8 on: September 28, 2007 - 05:41:40 PM »
I got a 192 or 193 stat in mine with the rallye dash and everything new like radiator 3 row, thermal fan, water pump, and my gauge reads 1/3 the way up idling or driving. Once it's warm, it just stays there. I've let it idle a few times for 20 minutes, held it over 2000 rpms for 20 mins to break in the cam, and have drove it only 5 miles since new, but it doesn't show any signs of overheating. This is with a 22" radiator and a 440-6. I do have my timing and jetting set pretty close.  Air, fuel, and timing will cause havok on a cooling sytem temp if not within range :2thumbs:
« Reply #9 on: September 28, 2007 - 07:51:01 PM »
You have a 22" radiator with a 440-6?   :22yikes:
  I would have gone with a 26", but I'm glad it's working for you.  :thumbsup:
« Reply #10 on: September 28, 2007 - 09:46:08 PM »
My car came with a 22" radiator. And since it was a non a/c stick car I wanted to leave it the way it was. The radiator in it was actually for a 383 4 speed 1970. But I do feel lucky having no issues. I did clean the block good under the freeze plugs and as I said, it helps when you put everything in fresh and new.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #11 on: September 29, 2007 - 10:32:16 PM »
22" radiator without a shroud +
7 blade thermoclutch fan +
180° thermostat =
190° - 195° degrees.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
