Author Topic: Console rattle  (Read 3766 times)
Offline longgone
Console rattle
« on: September 27, 2007 - 08:42:44 PM »
I have a very nice console on my 70 cuda but man does the lid rattle if I don't keep my arm on it.  I'm wondering if I'm missing some rubber bumpers or spacers, mine doesn't have any, only the latch to hold it down.
Any tips?
Blueglow
Re: Console rattle
« Reply #1 on: September 28, 2007 - 02:08:45 AM »
the latch is adjustable & you could add a rubber strip or bumper to the lid
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Console rattle
« Reply #2 on: September 28, 2007 - 08:18:46 PM »
Any tips?
Blueglow
My console doesn't rattle, but the lid fits like crap :poopoke: It has been that way from day one.  From the pictures I attached, you can see how the rear of the lid has a gap.  There are no rubber bumpers from the factory.  My only guess is that maybe the hinge with the 6 screws can be adjusted...I have never tried.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: Console rattle
« Reply #3 on: September 28, 2007 - 08:49:21 PM »
I think if your lid is making a rattle, the spring in your latch isn't doing it's job. It should always be ready to spring open.
Re: Console rattle
« Reply #4 on: September 29, 2007 - 03:22:42 AM »
thwe hinge is slotted 2 ways to adjust up & down & alos front to rear , as well the latch is adjustable
Offline solarguy
Re: Console rattle
« Reply #5 on: September 29, 2007 - 05:24:03 PM »
Maybe it's all that junk in there   :grinno:
Offline hooD
  • detroit iron
Re: Console rattle
« Reply #6 on: September 29, 2007 - 10:02:43 PM »
Even without the junk its the same... :banghead:
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline hooD
  • detroit iron
Re: Console rattle
« Reply #7 on: September 29, 2007 - 10:09:42 PM »
Thanks for the info! I will try adjusting the hinge screws.    :bananasmi
i
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline TreeFrog
    • TreeFrog
Re: Console rattle
« Reply #8 on: October 02, 2007 - 08:42:25 AM »
pics look like its the cosole that is crooked, not the lid...
try Duct Tape
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline hooD
  • detroit iron
Re: Console rattle
« Reply #9 on: October 03, 2007 - 02:39:26 AM »
try Duct Tape
I adjusted the hinge and only got a slightly better fit.  I thought the same thing as you, that the console was crooked.  I removed both rear screws from the console and when i lifted the ashtray end of the console upward toward the lid, the gap was nearly gone.  But without anything other than a block of wood, i had nothing to shove under the console to hold it in a more level postion.  With some wood under the console, you could now see a gap between the console and the carpet.  I put it back together the crooked way it was, and called it a day.   :-\  I'm open to ideas to get it level.
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline TreeFrog
    • TreeFrog
Re: Console rattle
« Reply #10 on: October 04, 2007 - 09:00:46 AM »
could it actualy be a screw at the front that is too tight?
try taking all of the screws out and see if the unit is true, if it is slowly start tightening it down all the way around.
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
Re: Console rattle
« Reply #11 on: October 14, 2007 - 10:59:26 PM »
I took a small 1/4'' strip of self adhesive backed black foam weather stripping and ran it along the strip where the console door closes. Worked good...no rattles.
Now if I could just stop the pistol grip from rattling.... :swear:
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Re: Console rattle
« Reply #12 on: October 15, 2007 - 02:30:19 AM »
rebuild the shifter & pack it with greASE make sure the shims are not worn at the same time
Offline Ross
Re: Console rattle
« Reply #13 on: October 15, 2007 - 04:51:18 PM »
Keep you hand on it, be ready to go at any moment in time... :burnout:
'70 340 Challenger
A whole lot of rust and very little time to work on it...
Offline 73Chally
Re: Console rattle
« Reply #14 on: October 16, 2007 - 11:06:57 AM »
So did Blueglow have any luck?  Their problem sounds like it should just be a simple adjustment of the latch.  I had the same problem.
As for HooD, I hate to say it but it looks to me like the console itself is somehow twisted or out of wack.  If you pull it out and set it on a level surface, does the bottom sit flush along the whole length?  If not, then that could be the problem.  The lid looks flat, and I would think it would be real obvious if the lid was bent that much.  Just my  :2cents:
