Author Topic: Best Performance Heads for 340???  (Read 19363 times)
Re: Best Performance Heads for 340???
« Reply #30 on: January 17, 2006 - 11:33:23 PM »
I have worked with the big block indys they are a good head , not a big fan of the external oiling , I think it may put to much oil to the heads , the EZ series doesn`t have external oiling
Offline Follicly Challenged
« Reply #31 on: January 17, 2006 - 11:50:56 PM »
INDY SB heads are "the stuff" for really serious street efforts. We've made 545 hp and 540 torque with 'em on "pump fuel", real solid curves too !, in a 408 stroker, using a relatively mild 246/251 Mech. Flat tappet Cam. Thats "plenty" for a stock sb Mopar Block to take, even W/mainstuds.
Bowl cleanup only, real close to "outa the box". They're a serious head ! Only way to buy them is in the "K Kit" form, 360-1K rect port, or, 360-2K oval port, complete, everything from block up to the carb, Headgaskets, manley head bolts, valvetrain, etc., etc., everthing included.
The heads even feature "dual bolt pattern" for use on race blocks. On stock blocks you may have to cut off a couple of bosses to clear headers. Keep the "removed bosses" as they can be welded back on later if you get a better block later.
Just my experience, no wars wanted,  Bob out.
Offline matt63
« Reply #32 on: January 18, 2006 - 08:08:02 PM »
I'm just putting together this 408 stroker with an LA bottom end and a Edelbrock Magnum top end.  The heads have been cleaned up, different springs,back cut valves, flow test and a gasket match.  We'll see how they work in the spring!
Matt in Edmonton
'68 Valiant
Offline jvike
  • Pro-Touring Cuda
« Reply #33 on: January 19, 2006 - 12:05:39 AM »
Looks real nice!  :wow:
Oldschool
« Reply #34 on: January 19, 2006 - 10:35:39 AM »
Looks sweet Matt!   :ylsuper:  Let us know how it works when you install it and tune it up.   :cooldancing:  .....Oldschool
« Last Edit: January 19, 2006 - 11:01:34 PM by Oldschool »
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #35 on: January 19, 2006 - 12:15:51 PM »
What's the best low-rise intake? I need to fit nuder the shaker & have the hood close  :)  I currently have a single plane offenhauser. Is the 2-plane air gap better?? Or is there others that rip the competition? Thanks
71fish
71fish - Nobody better than an E-BODY!!
Offline matt63
« Reply #36 on: January 19, 2006 - 10:22:12 PM »
Looks sweet Matt!   :ylsuper:  Let us know how it works when you get you install it and tune it up.   :cooldancing:  .....Oldschool
Thanks guys. Spring can't come soon enough!
Matt in Edmonton
'68 Valiant
