Author Topic: Just another 318 Challenger  (Read 110454 times)
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
Re: Just another 318 Challenger
« Reply #525 on: December 25, 2013 - 01:23:06 PM »
Yeah that is cool.  :popcorn:
Offline larry4406
« Reply #526 on: December 26, 2013 - 09:43:30 AM »
Some details please on the sunroof.  Was the donor a mopar or was it another model?
Offline farmboy70
« Reply #527 on: December 26, 2013 - 10:42:55 AM »
It was a pretty well stripped out for parts 70 Challenger.
I was able to get the top and power windows setup.
Power top is very complete with only the switch and motor coupler missing.
 I'll be added in power windows after I complete the top part of the project.
Offline farmboy70
« Reply #528 on: December 30, 2013 - 07:24:06 PM »
Getting a little closer .
Worked on placing the drain hoses and fitting the box one more time.
Tonight I bonded the box in for the final time.
Next step will be trimming the roof panel and gluing the top material back down in place.
The slider panel has a few small pin holes that need repair and then test fit it.
Everything is glued and drying over night.
Offline 70 RT Convt
« Reply #529 on: December 30, 2013 - 07:41:35 PM »
Looks great Dave , I am glad to see you still have the car.
1970 R/T Challenger Convertible
2011 R/T Classic
Offline usraptr
« Reply #530 on: December 30, 2013 - 07:44:56 PM »
Looks good!  :2thumbs:  You've got a lot more guts than I have to try something like that!   :ylsuper:
(Edited 8-1-17)
« Reply #531 on: December 30, 2013 - 08:46:19 PM »
 :iagree: no changing your mind now!  :lol: Must be a special headliner used with sunroofs? :dunno:
Offline farmboy70
« Reply #532 on: December 30, 2013 - 09:07:11 PM »
It is a cloth type head liner with out the bows in the sunroof top area.
It uses two bows in the rear.
I'm going to try and reuse my headliner, that will be iffy but I'll give it a shot before buying a new one.
Offline dutch
« Reply #533 on: December 31, 2013 - 12:33:10 AM »
very nice  :2thumbs:   glad to see you keep the gator top   :cooldancing:
*** Bart ***
« Reply #534 on: December 31, 2013 - 06:15:54 AM »
Very cool and interesting project!  :2thumbs: Some thoughts that occurred to me....? What happens if something fails, like it gets stuck in the open position. How easy is it to service? You mentioned using bonding adhesive. Is that in place of where the factory would have used spot-welds ? :dunno:
Offline farmboy70
« Reply #535 on: December 31, 2013 - 07:37:33 AM »
If it gets stuck open you just drive fast and the rain won't come in. :roflsmiley:
There are two pins you pull and release the top panel to slide forward.
The top runs with cables like a bike brake cable.
A gear drives the top from the housings on the cable, the wear is usually in the aluminum guide  tracks.
Mine look really good though.
I'm trying the panel bonding glue in place of all the spot welds around the opening.
The box is supported by brackets screwed to the roof frame work so most of the weight is supported there.
Offline ShelbyDogg
« Reply #536 on: December 31, 2013 - 08:13:29 AM »
I had a 74 Dart Sport Convertriple with a sunroof that had a bad motor, I would just unlatch each side, drop the rear, then slide the whole thing open or closed.  The Challenger "body service manual" manual shows pulling a plug then inserting a tool, then cranking the e-body's top open or closed.
Brad,
There is a bare sunroof section with pics in the "for sale" section if you want to see one.
Here: http://www.cuda-challenger.com/cc/index.php?topic=95978.0
« Reply #537 on: December 31, 2013 - 06:27:45 PM »
Interesting thanks! Curious to see it finished! :2thumbs:
Offline hemiken
« Reply #538 on: December 31, 2013 - 06:28:57 PM »
It is looking awesome Dave :clapping: :jumping:
They are a huge hole when all completed, and it is an awesome addition to your already beautiful car buddy :drool: :2thumbs: Can not wait to see it all buttoned up and working in the car, are you going to go through the electric windows with install pictures too buddy. :dunno:
Happy New Year Dave :bigsmile: :wave:
Offline farmboy70
« Reply #539 on: December 31, 2013 - 07:07:12 PM »
Sure I can do the windows too.
Sent the workers home early and took bosses privilege to work on my car some. :2thumbs:
Finished final trim on the box to roof skin and painted it.
 Tomorrow will probably glue the top material down.
