Author Topic: Just another 318 Challenger  (Read 110461 times)
Offline hemiken
Re: Just another 318 Challenger
« Reply #510 on: December 14, 2013 - 05:49:04 PM »
Man that was a good score getting all of those parts from that one parts car, that will make the conversion so much easier, i can not wait to see it all fitted back up :jumping: and Gatorized :drool:
Offline farmboy70
« Reply #511 on: December 23, 2013 - 05:18:27 PM »
Spent yesterday test fitting the sunroof box and adding the drain holes.
Today did the scarey part and cut the material away for the finish cut in the roof panel.
 The roof pealed away so I think we maybe able to save the top on it and just use the extra piece I bought from Legendary.
Still a ways to go to be sure but so far so good.
Dave
Offline hemiken
« Reply #512 on: December 23, 2013 - 05:36:41 PM »
Cool update :clapping: This is going to look trick :bananasmi
« Reply #513 on: December 23, 2013 - 06:27:45 PM »
Loving that gator grain! :2thumbs:
Offline DAYLEY/CHALLENGER
« Reply #514 on: December 23, 2013 - 07:33:50 PM »
WOW.............cutting a hole in the roof...........and I was scared when I put port holes in my 76 ford van................ :worshippy
Dave or David
« Reply #515 on: December 23, 2013 - 08:23:33 PM »
Do you plan to epoxy glue the inner sunroof frame into place?
Offline farmboy70
« Reply #516 on: December 23, 2013 - 08:48:35 PM »
The plan as of now is to use structural adhesive to bond the understructure to the roof panel and use tack welds in the corners . Rescrew the mount braces.
Originally the box was spot welded to the roof panel.
 and screwed at the mounting braces.
 I feel we need to keep the heat down or warp the roof panel with mig welds.
 Dave
« Last Edit: December 23, 2013 - 08:51:05 PM by farmboy70 »
« Reply #517 on: December 23, 2013 - 08:53:36 PM »
The plan as of now is to use structural adhesive to bond the understructure .
 Dave
Yeah, I meant something like that.
Offline farmboy70
« Reply #518 on: December 23, 2013 - 09:03:39 PM »
I think it should work OK , but I would prefer to weld the whole outside.
 We are trying to save the top that is on it now, so welding it all would likely damage top material.
 If on the other hand we can't work the top edges correctly I will remove the whole top and weld it. Then install a new top.
 I already purchased one just in case we fail.
  If we get it  I will resell the top.
 Dave
Offline IMNCARN82
  • LeDZeP
« Reply #519 on: December 24, 2013 - 05:12:40 PM »
cut that sucker!!!    :poopoke:       Yur nutS !!!   Gotta luv it!!!         :popcorn:       R/T
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline farmboy70
« Reply #520 on: December 24, 2013 - 05:51:02 PM »
Well here we go!
Offline farmboy70
« Reply #521 on: December 24, 2013 - 05:54:24 PM »
Next step will be putting the box in for the final time. Running the drain hoses, then working the top material.
Merry Christmas
Dave
Offline hemiken
« Reply #522 on: December 24, 2013 - 08:44:15 PM »
Hey Dave, their is a hole in your roof :faint: good luck buddy, i am loving the modifications. Merry Christmas Dave :wave:
Offline IMNCARN82
  • LeDZeP
« Reply #523 on: December 25, 2013 - 12:41:42 PM »
Nice Dave!  And Merry Christmas to you too!  Howdja cut that hole?  Looking great from here!  R/T
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline farmboy70
« Reply #524 on: December 25, 2013 - 12:51:18 PM »
We put our heads together and came up with.
 Peeled top back some and pushed in a piece of metal to protect the top material. Drilled a hole large enough to allow the electric shears to cut the straight edges, then die grinded the corners.
 Worked great!
 Scott who works for me and Steve a good friend are pictured.
They would only let me man the camera!
They said my patience level working on my own car was not good and they were going to cut it.
Dave
« Last Edit: December 25, 2013 - 12:52:52 PM by farmboy70 »
