Author Topic: How much Slick will fit ?  (Read 1629 times)
Offline 440mike
« on: September 30, 2007 - 04:26:37 PM »
Hi guys, I searched the "tire,wheel & susp" thread, couldn't find any definite answer.
So here goes.
I need to get as much Slick as possible under my 71 Challenger, WITHOUT resorting to cutting the car up. Does anybody know, or, can rec. what I can safely buy.
Does a 10 inch rim fit with a 5 inch backspacing
71 Challenger
Stock 8 3/4 width diff.
mike.
moparniac
Re: How much Slick will fit ?
« Reply #1 on: September 30, 2007 - 04:35:10 PM »
I run a 10" rim with 5" backspace but I use a 3/4 relo kit...
Offline 440mike
« Reply #2 on: September 30, 2007 - 04:52:14 PM »
This may sound stupid, but whats a 3/4 relo kit ?  How much tire does that allow ?
thx, mike
« Reply #3 on: October 01, 2007 - 02:10:07 AM »
the relocation kit is offset front & rear leaf mounts to move the spring inward , without doing this I would recommend a 11" wide tire on an 8.5 rim with 4" back set
Offline 440mike
« Reply #4 on: October 01, 2007 - 06:27:11 PM »
Thank you .
moparniac
« Reply #5 on: October 01, 2007 - 08:06:47 PM »
I have the rear 3/4 relo shackles if you were interested...
Offline 440mike
« Reply #6 on: October 02, 2007 - 03:24:16 PM »
Thanks again guys.
I found them on the Mopar Performance site. It lists the "offset rear spring front hangars", and the "offset rear shackles".
I assume I need both to move the springs in ?
How much power can they hold ? Same as the stock stuff ? I was thinking of using/buying these offset things to get more tire under it, and installing a set of Caltrac bars ?
Does that seem like a practical approach for 11's ?
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #7 on: October 02, 2007 - 04:06:31 PM »
You will have to move the perches on the rear axel to, - or find a B-Body rear... :working:
« Last Edit: October 02, 2007 - 04:36:49 PM by cowboy »
moparniac
« Reply #8 on: October 02, 2007 - 04:32:09 PM »
I used a b body rear and the perches are already where they need to be...you dont need caltracs using SuperStock springs...
the 3/4 kit will handle anything you throw at it..
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #9 on: October 02, 2007 - 04:38:49 PM »
I do... :burnout:
moparniac
« Reply #10 on: October 02, 2007 - 04:42:55 PM »
why would you need them... have they even lowered your 60ft......
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #11 on: October 02, 2007 - 04:48:03 PM »
Yeps.  Before I would have a little spinnin wheels, or a rear "jumpin"...??? Now it just take of...
moparniac
« Reply #12 on: October 02, 2007 - 04:49:17 PM »
are you sure your running superstock spings???
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #13 on: October 02, 2007 - 04:51:00 PM »
99,9% sure.. :bigsmile:
moparniac
« Reply #14 on: October 02, 2007 - 05:05:33 PM »
Nothing against you but I wa told that the caltracs were useless with ss springs??? what was your 60ft before and after caltracs??? just curious???
