Author Topic: Rear sway bar-how to install  (Read 929 times)
Offline mikeinsjc
« on: October 02, 2007 - 02:32:38 PM »
I am going to install a rear sway bar on my 70 Challenger. It did not come from the factory with one. My question is: when I drill the frame rails for the bolts, what should be the attitude of the rear end, or does it matter?, i.e. should the car be jacked up, or should it be in its normal ride position? All components are factory stock.
70 cuda
70 challenger
69 6 pack rr
Re: Rear sway bar-how to install
« Reply #1 on: October 02, 2007 - 02:39:19 PM »
OE location orients the sway bar the correct distance to the rear...I suppose if you have a radically altered rear suspension there may be allowances that would need to be made. Here is a drawing I made some time ago for another board member that said it worked well for him. Measurement to the lower bolt from the point the frame rail turns up.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: October 02, 2007 - 02:52:16 PM »
 :iagree: Mine also mounted in that location, in fact because the 'U' channel brackets are tapered, they pretty much end up there anyway.
Kurt - SE Michigan
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #3 on: October 02, 2007 - 03:19:05 PM »
mine was removed for racing.. so I'm also looking to install. I have all the parts but no directions.
71fish - Nobody better than an E-BODY!!
Offline Ross
« Reply #4 on: October 05, 2007 - 02:02:51 PM »
The one that I bought from mopar performance 8 years ago was to be installed at road height.
I recall they stated to set the link pieces from the axle verticle and then mount the swaybar to them.  Where it sits is where you drill for the 2 squared U bolts.
'70 340 Challenger
A whole lot of rust and very little time to work on it...
