Author Topic: How should the underside be painted?  (Read 1593 times)
Offline jeryst
« on: October 02, 2007 - 11:26:22 PM »
I see a lot of restorations where the underside of the car is painted the same as the body color. But I had several Mopars and none of them had the underneath painted.
So if you are going for accuracy, how should the underneath be treated?
Offline 70_challenger
  • Suburban Detroit, Michigan
Re: How should the underside be painted?
« Reply #1 on: October 03, 2007 - 12:19:39 AM »
How should it be painted?  However you are happy with it.
The factory did not specifically paint the underside.  At the factory, they shot paint at the rocker panel, and some of it oversprayed onto the bottom of the car.  So most cars have paint extending about a foot or so under the car.  (My 2006 Chrysler is the same way!)
Having said that, most of us are building these cars to drive, and want the added protection and good looks of paint under the car.  (I realize this is one glaring inaccuracy in my resto, but I want it to look nice!)
If you are going for accuracy, I would suggest duplicating the factory job by not painting under there.  But I would make sure to have some good protection of the undercarriage (epoxy primer or something...)
 :2cents:
-Tom
Offline PlumCrazy
« Reply #2 on: October 03, 2007 - 03:41:04 PM »
Similar to this.
Offline 426 pentastar
« Reply #3 on: October 05, 2007 - 02:36:19 PM »
It really depends on it being an undercoated car or primed car.I have had three low milage mopars that were primed cars from the factory.The color is either a gray or an off red oxide,you can duplicate this using paint instead of true primer.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #4 on: October 05, 2007 - 03:33:36 PM »
A little off topic but question came up by the photo posted, I did not realize you could get a hemi car with a 8 3/4? Anyone know how many were made? I thought they all had dana's in them.
1996 Dodge Viper GTS Coupe
« Reply #5 on: February 15, 2009 - 07:55:11 PM »
Hi,I recently sold a 1967 low milage Charger Hemi car that had never been touched and yes it did have a 8/34 under it with 355 gears and everything matched the build sheet.
« Reply #6 on: February 15, 2009 - 09:26:57 PM »
the bodys were dipped in Grey primer so the corrct look is to copy the pic above , I have used epoxy primer to imitate the look , it has the falt finish But will stand up to rust easily
 All Hemi Automatic built cars had the 8 3/4 as std equipment , you had to order the Track Pack option with A32 for 3.5 or A33 for 4.10 gears to get the Dana with an auto
 the Hemi 4 spd cars had Danas as std equipment
Offline go-fish
« Reply #7 on: February 15, 2009 - 09:48:26 PM »
Very interesting. I never would have guessed that.
« Reply #8 on: February 15, 2009 - 10:08:26 PM »
Here's another good example underneath.
Alaskan_TA
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #10 on: February 16, 2009 - 09:18:07 PM »
70 Challnger is right - sure looks better painted - but a galring example none the less...Mine's getting undercoat/chassis black, which is the lame ass lazy way to get around doing either!
Offline ksierens
    • 70 Challenger Resurrection
« Reply #11 on: February 17, 2009 - 12:50:29 PM »
I used SEM Trim Black on mine because I like the way it looks, and because I can touch it up easily.
Kurt - SE Michigan
Offline 1968cuda
  • Restoring: 68 Cuda. Driving: 74 Roadrunner
    • Carl's Cuda Page
« Reply #12 on: February 18, 2009 - 09:49:38 AM »
HA HA.  I am just painting mine with 2 coats of gloss black rustoleum.  It's cheap and comes in spray and brush on :working:
I have a website dedicated to my restoration.  View here:
http://1968cuda.googlepages.com/
Offline mcgheejt
« Reply #13 on: February 20, 2009 - 11:05:13 AM »
This shows the factory dip process;
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1972/72_Dodge_Engineering0010.jpg
I love these documents: "Dodges famous 7-step dip and spray process for maximum protection against all forms of corrosion."   :screwy:  We should all be able to sue for false advertising.   :roflsmiley:
