Author Topic: wiring for electronic ignition  (Read 685 times)
Offline RaptorF229
  • A work in Progress
« on: October 03, 2007 - 03:49:58 PM »
Looking at the current ballast resistor that I have in the picture. I know about the wires from the ECU going to the coil. I just want to make sure that the blue wire from the ECU goes to the correct dark brue wire but is the dark blue wire at the far left or second from the left . Also do I need to remove any of the other wire from the ballast resistor?
Offline RaptorF229
Re: wiring for electronic ignition
« Reply #1 on: October 03, 2007 - 11:53:49 PM »
never mind I got it.  thanks for the help guys
