Author Topic: Basecoating over Acrylic??  (Read 1110 times)
Offline wally426ci
    • maryland mopars
« on: October 05, 2007 - 10:19:49 AM »
So, im gonna spray my engine bay this spring but heres the catch. Ive got Acrylic Enamel under the hood and door jams, but my car is Basecoat clear. So, can i go over Acrylic with basecoat or am i gonna have to strip the enamel first ......
 :feedback:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Rare_T_A
    • Freiss Family Mopar Site
Re: Basecoating over Acrylic??
« Reply #1 on: October 05, 2007 - 10:35:10 AM »
I did it to mine. I just scuffed the enamel and B/C it.
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
Offline wally426ci
    • maryland mopars
« Reply #2 on: October 05, 2007 - 12:08:48 PM »
Sweet, thats what i was hoping to do myself....  :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline farmboy70
« Reply #3 on: October 07, 2007 - 05:10:17 PM »
If the enamel has a hardener in it when sprayed you should be fine. If you use PPG DBC system be sure to use DX 57 in the base.
Offline moper
« Reply #4 on: October 09, 2007 - 11:44:46 AM »
Just dont use laquer for prime or color stuff. That's if you could even still get it. either enamel or urethane will be fine.
Offline wally426ci
    • maryland mopars
« Reply #5 on: October 09, 2007 - 11:51:23 AM »
whats this dx57 farmboy speaks of??
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline matt63
« Reply #6 on: October 09, 2007 - 12:01:31 PM »
You might want to talk to the paint supplier about using a sealer.  My understanding is that this product prevents compatibility problems with different paint types.  I know that this product was used on my Demon when it was painted.
Matt in Edmonton
'68 Valiant
Offline farmboy70
« Reply #7 on: October 09, 2007 - 12:57:32 PM »
DX-57 is a additive for  PPG DBC base coat paint. It allows touch up later without a possible lifting problem If it needs to be resprayed. It also makes the base a little easier to check color match over the full flat look of base with out it.
Offline wally426ci
    • maryland mopars
« Reply #8 on: October 09, 2007 - 02:33:55 PM »
ah, thanks. now, i've got another question in this area. how about touching up small areas with Bc/Clear. can i wetsand a small area of a panel, color whats needed, and clear out over a little wider area and actually wet sand and buff it un-noticeably?? or am i gonna have to clear the entire panel.
i figure i may be able to feather off at the end of the clear coat and blend it in with the rest of the clear coat.
 :dunno:
thanks for all of the help guys.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline farmboy70
« Reply #9 on: October 09, 2007 - 04:31:02 PM »
Yes and no. If you know what clear is on it now you may be able to do it ,if not it may cause several problems.
I would clear the entire panel to keep from having a dry line appear later as the clear edge drys at a different rate than what is on it now.
If you want to do the clear blend use a blending solvent to go over the blend area. This will allow the edge to be buffed in easier.
Again though I would clear the entire panel over this method.
