Author Topic: Painting an engine  (Read 1190 times)
Offline burrpenick
Painting an engine
« on: October 05, 2007 - 10:36:15 PM »
I'm rebuilding my 360 and its been dipped. A buddy tells me I should first spray a coat of urethane primer and then use the high heat engine paint. I like that primer and it seems to be tough, but is that what is recommended? I will not be painting the intake or valve covers, so there is really not much to cover.
Thanks, George
GEORGE
currently Moparless
Re: Painting an engine
« Reply #1 on: October 06, 2007 - 03:47:23 AM »
if the primer is not heat resilient it can lift the paint above it , I would be more inclined to use an epoxy paint , not sure what works best
Offline farmboy70
« Reply #2 on: October 07, 2007 - 05:46:24 PM »
Clean the bare metal with a good metal prep cleaner like DX 579. This will remove any assembly lube,minor rust and any other contaminates.
Clean it again with a good wax and grease remove like DX 330.
Then clean again with Dx 394. This will remove any organic contaminates.
Spray it with a epoxy primer like DPLF 50 with 402 catalist.
Then good to color.
« Reply #3 on: October 07, 2007 - 06:47:03 PM »
This would be worth trying prior to paint. But only a light coat.
Hi Temp Aerosol Primer
Hi-Temp Engine Primer.
Only Needed On Smooth Surfaces.
No Need To Primer Cast Parts.
12 Oz. Aerosol.
http://www.hirschauto.com/acb/showdetl.cfm?&DID=27&User_ID=520122&st=5451&st2=-611474742&st3=620713285&Product_ID=5&CATID=1
Offline GoodysGotaCuda
« Reply #4 on: October 07, 2007 - 08:20:06 PM »
i duplicolor engine primered everything, then used their paint. Pretty happy with it. Wish i woulda polished the valve covers up a bit more. Oh then i high temp clear coated
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Rare_T_A
    • Freiss Family Mopar Site
« Reply #5 on: October 11, 2007 - 11:59:23 AM »
On the T/A I used PPG epoxy primer first. Then I used PPG base/clear for the color. The paint is automotive HEMI Orange and the same for the clear. I did the same to the RR and it has over 8K miles and looks the same as the day it was installed.
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
Offline ntstlgl1970
  • T a c o c a t
« Reply #6 on: October 11, 2007 - 05:34:22 PM »
I used a wire brush, then brake cleaner, then wax and grease remover to get my engine pretty clean. Then DP60 and Deltron
