Author Topic: Dana 60 Rear End Opinions  (Read 1751 times)
Offline longgone
« on: October 08, 2007 - 06:38:05 PM »
Thinking about swapping the 8 3/4 rear end in my 70 cuda for one of the newer manufactured Dana 60 style rear ends.  Getting ready to put the Keisler 5 speed in it and while I've got the whole drivetrain out of it and having to have a drive shaft cut to length, I thought if I was ever gonna throw a Dana 60 under there, now would be the time....
Few questions.
1. Is the Dana 60 swap worth going through?  I'm estimating about $2k-2.2k for the swap.
2. What do you thing of the Strange Engineering Dana 60s?
3. What else would you consider or look at?
4. Or am I just crazy overboard in this resto job I'm doing  :villagers:
Thanks
Blueglow
Offline ntstlgl1970
  • T a c o c a t
Re: Dana 60 Rear End Opinions
« Reply #1 on: October 08, 2007 - 06:50:53 PM »
Street Car or Race Car?
Do you need a dana or just want it for bling factor?
IMO Unless you make some good (like 5-600) horsepower and run sticky tires (drag T/A's or ET streets or slicks) if prepped right the 8 3/4 should be fine.
If you go with the dana, I think any of the companies supplying them would be fine.
Offline longgone
« Reply #2 on: October 08, 2007 - 08:35:58 PM »
Its a street car.  Motor is 440-6pack built fairly well but nothing too hardcore.
Blueglow
« Reply #3 on: October 08, 2007 - 09:50:52 PM »
as long as the tires will spin the 8 3/4 will live , put slicks on it & the diff could fail , your call
Offline willhaven
« Reply #4 on: October 08, 2007 - 11:25:31 PM »
I hear that both Strange and Moser make great units. Moser being the slightly cheaper choice if I recall correctly.
I'm getting a Moser dana with the aluminum rear end cover for my car.
Offline Carlwalski
« Reply #5 on: October 08, 2007 - 11:39:10 PM »
If you can afford to do it I say do it now. Be safe than sorry, especially with a Tremec trans. You'd be fine with the 8-3/4 but you'll be safer with a Dana. I'd go with a Dr-Diff Dana 60 (he uses Strange housings). I did & I'm happy as.
:2cents: :wave:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #6 on: October 08, 2007 - 11:54:25 PM »
What kind of cost from Dr. Diff?
1996 Dodge Viper GTS Coupe
Offline Carlwalski
« Reply #7 on: October 09, 2007 - 12:08:04 AM »
Varies and depends on what you want. Discs, drums, style of rear (E or B) custom with, yokes, gears......
Check out Cass' website for options & prices, they're very competitive.
http://members.aol.com/doctordiff/dana.html or email: doctordiff@centurytel.net :thumbsup:
Offline 72hemi
« Reply #8 on: October 09, 2007 - 12:57:07 AM »
Thanks. I have been looking for a website from him.
Offline bigblue73
« Reply #9 on: October 09, 2007 - 08:55:23 AM »
I agree with NZ. :iagree:  If you are going to the extreme for durability also upgrade the brakes for safety.
Offline hemi71
« Reply #10 on: October 09, 2007 - 05:39:59 PM »
The 8 3/4 is a stout rear, and in street trim it's fine. The tires will blow off in smoke before you will hurt that rear (they act like a fuse). Now put a set of slicks on the car and a sticky track with 500lbs/ft torque and then you will start to see the limits of the 8 3/4. Unless you want the wow factor of the dana 60 (and it's added 50 +/- lbs) stay with the 8 3/4. Much easier to change the rear ratio in an 8 3/4 also...easy center section swap verus a PITA with the dana.
Offline wiging19
« Reply #11 on: October 10, 2007 - 11:27:01 AM »
I agree with the previous posting about the 8 3/4.  On the other hand having a dana rear end on your car is a big deal to alot of people.  The only other part on most cars people want to know is does your car have a hemi?  Those two parts definately have the wow factor for most people who aren't informed about what the different parts can do from a performance point of view.  I destroyed my engine and transmission but the 8 3/4 still hung in there.  As Hemi 71  said for most purposes a good 8 3/4 will get the job done for you.  With that said I have to admit when replacing the rest of my drive train I put in a dana with a lower gear ratio than I had with the 8 3/4.   This time around I'm not risking any part of my drive train going south on me without some extra-ordinary effort on my part.  :working:
