Author Topic: Mopar Performance cast air cleaner element?  (Read 1051 times)
Offline miketyler
    • www.miketyler.net
« on: October 09, 2007 - 07:18:17 PM »
Do they make a 13 1/4" low profile air cleaner element for the MP cast air cleaner? It clears my hood ok but just looks too tall. Anyone been there, done that?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Re: Mopar Performance cast air cleaner element?
« Reply #1 on: October 09, 2007 - 07:31:06 PM »
Mike,
  I haven't seen such an animal.  :grinno: The problem is, if you shrink that much more, you are hurting air-flow. For what it's worth, I have the K&N air-filter on mine, but it has a drop-down base plate. I wonder if you mated their base plate to the Mopar air-filter...  :naughty:
Offline GoodysGotaCuda
« Reply #2 on: October 09, 2007 - 07:33:06 PM »
Only thing i found was i had a ford racing drop base air cleaner sitting around that was the same diameter. got lucky i guess!
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: October 09, 2007 - 09:46:55 PM »
you can buy a drop base A/C for cheap & just use the base
Offline Robb
« Reply #4 on: October 10, 2007 - 01:28:40 AM »
take the element with you to autozone/napa/checkers whatever.   ask them for one or start digging thru their boxes.   you can probably find one that will work that is list for some other car out there.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
« Reply #5 on: October 10, 2007 - 02:45:21 AM »
K&N has a measurement search, even lists the models they fit.
http://www.knfilters.com/search/univ2.aspx?ID=S0001
Offline miketyler
    • www.miketyler.net
« Reply #6 on: October 10, 2007 - 06:21:05 AM »
Quote
take the element with you to autozone/napa/checkers whatever. Ask them for one or start digging thru their boxes.  You can probably find one that will work that is list for some other car out there.
Did that, and found one but it was only 1/4" shorter than the stock unit. Checked all their Fram and STP stock. I'll check that K&N site, thanks
72' Cuda restomod
70 Mustang Mach 1
