Author Topic: Rear exhaust mount - heat shield between mount and body?  (Read 1596 times)
Offline OzCuda
« on: October 10, 2007 - 08:44:24 AM »
I noticed in the factory service manual that the rear-most exhaust hangers had a layer of heat-shield between the external bracket and the body.  Can anyone tell me what this was made of and whether it is necessary to replace it?
'70 Barracuda
Offline ksierens
    • 70 Challenger Resurrection
Re: Rear exhaust mount - heat shield between mount and body?
« Reply #1 on: October 10, 2007 - 08:48:37 AM »
My guess would be that it was asbestos, you could probably get some of the muffler bandage material from the auto parts store.
Kurt - SE Michigan
Offline wiging19
« Reply #2 on: October 10, 2007 - 10:57:23 AM »
Actually it is a metal shield.  You can buy them because I bought replacements via advice from here.  I also bought the hanger for the driver side of the car for the exhaust system if your putting in dual exhaust in a single exhaust car.   I'm sure someone will tell you the vendor because earlier this year there was a long thread on this.  I'm glad I purchased the items I mentioned and I'm looking forward to putting them on the car.  :bigsmile:
Offline ksierens
« Reply #3 on: October 10, 2007 - 12:39:18 PM »
Hmm, I thought he meant the bracket that is installed from inside the trunk that holds the rear most hanger.  :clueless:
« Last Edit: October 10, 2007 - 06:39:55 PM by ksierens »
Kurt - SE Michigan
Offline wiging19
« Reply #4 on: October 10, 2007 - 05:12:51 PM »
The company that sells the heat shields also sells the hangers.  I bought the heat shields from year one:
JS6061LHRH  heat shields ~ both sides
SR196 ~ heat shield bolt set
The passenger side exhaust hanger I can't remember where I got that piece.
Offline OzCuda
« Reply #5 on: October 11, 2007 - 09:29:53 AM »
Not after the metal heat shields, had one and bought the other to convert to dual exhaust.  It seems that the exhaust hanger itself has a layer of insulation between it and the boot floor.  Got some heat wrap today and will give that a try.  Obviously the factory thought that this was a high heat transfer location.
'70 Barracuda
Offline OzCuda
« Reply #6 on: October 13, 2007 - 05:33:10 AM »
So I'm a complete gumby - the heat shield referred to in the manual were the metal heat shields above the mufflers.  Think first - post second :-[
'70 Barracuda
Offline RusTy/SE
  • Just havin' fun
« Reply #7 on: October 13, 2007 - 01:10:49 PM »
No worries mate :) If all your misreads are as easy to recover from as this, you'll be done in no time :cheers:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline trouble
« Reply #8 on: October 14, 2007 - 05:49:27 PM »
Are the heat shields above the mufflers there because the gas tank is right there?
Offline wiging19
« Reply #9 on: October 15, 2007 - 04:53:21 PM »
Yes.
