Author Topic: Trans temp oil Temp gauges needed?  (Read 683 times)
Offline Mike71Cuda
« on: October 10, 2007 - 11:42:19 PM »
I have fuel pressure oil pressure and water temp afternarket gauges (auto-meter pro comp)
Do I really need the others? Yes it would be great, but neccasary? Too many non-factory gauges always turned me off.
I think I would rather have pyro gauges for left and right side of exhaust to see lean/rich conditions
Thoughts?
Re: Trans temp oil Temp gauges needed?
« Reply #1 on: October 11, 2007 - 02:13:12 AM »
I would pass on the trans temp guage unless you are have a recurring problem with trannys , I had one trans guy tell me that the guage can cause a failure by inserting a probe into the line it blocks the flow somewhat & can actually cause a problem , not sure if that is actually true but I would be very careful not to restrict flow if you install a guage anyway
moparniac
« Reply #2 on: October 11, 2007 - 05:40:52 AM »
no problems on mine at all yet...but I am also runnin -6an which is bigger than stock....I got alot of money in my tranny so im all for it....the probe on the sending unit does not go up into the line on my setup so no blockage :working:
