Author Topic: Hemi plug wire loom brackets  (Read 1028 times)
daves70
« on: October 11, 2007 - 08:11:11 PM »
Can anyone tell me where to find the spark plug wire loom brackets for the back 2 plug wires on each side that slide on to the metal brackets on the valve covers? Also, does anybody know what goes under the bendable clamps on the one valve cover? Is it the ground wire to the block or maybe the wire to the starter? Dave
Re: Hemi plug wire loom brackets
« Reply #1 on: October 11, 2007 - 08:22:38 PM »
Here is how they are supposed to be configured.
daves70
« Reply #2 on: October 11, 2007 - 09:19:36 PM »
Yours are different than mine. I only have the brackets in the center and you show to have them in the front too. Possibly different year? Dave
« Reply #3 on: October 11, 2007 - 10:36:25 PM »
The reproduction Hemi valve covers appear not to have the wire holders built in where all 4 meet together. But I would get that verified.
These are OEM valve covers pictured.
« Reply #4 on: October 12, 2007 - 03:45:09 AM »
daves70
« Reply #5 on: October 12, 2007 - 09:50:51 PM »
These are OEM valve covers pictured. Yours are totaly different than mine. Mine are older than yours. You have the turn off oil filler cap. Mine have no place for that. I know mine are original and not repo. Yours must be for a 70-71.
« Reply #6 on: October 12, 2007 - 10:21:28 PM »
Yes I saw the oil filler breather cap style on yours but didn't mention it because that was obvious and that you knew that already.
So it seems true that the 70-71's had the 4 wire flange on the front of the valve covers and earlier V/C's didn't.
