Author Topic: posi fluid  (Read 1074 times)
Offline 73 challenger 440
posi fluid
« on: October 13, 2007 - 12:24:53 PM »
i need to change my fluid in the  rear end, what weight do I need and is there posi additive I need as well..
thanks
Offline RaptorF229
  • A work in Progress
Re: posi fluid
« Reply #1 on: October 13, 2007 - 12:41:00 PM »
I use amsoil SVG and the Slip Lock additive. ITs all synthetic stuff.
gearoil
http://www.amsoil.com/storefront/svg.aspx
sliplock
http://www.amsoil.com/storefront/ada.aspx
Re: posi fluid
« Reply #2 on: October 14, 2007 - 03:30:21 AM »
2 choices , 80-90w gear oil or synthetic 75-90w not brand specific
 most oil require friction modifier added unless it specifies otherwise
Offline ksierens
    • 70 Challenger Resurrection
Re: posi fluid
« Reply #3 on: October 14, 2007 - 09:09:21 AM »
I used to buy mine from the GM dealer, I will see if I still have some, but I think I heard somewhere that it was no longer available.
I think that Jay Leno had mentioned something about some trans/rear additive that he was using that he liked in the Challenger video on his web site.
Kurt - SE Michigan
Re: posi fluid
« Reply #4 on: October 14, 2007 - 08:49:41 PM »
my Dad has some gm posi additive, but not sure if I can use that, I am not sure if the corvette rearends are different.. I went to pepboys but that didn't have any amsoil
Re: posi fluid
« Reply #5 on: October 15, 2007 - 03:08:39 AM »
GM & Mopar additive is the same stuff
kudakidd
Re: posi fluid
« Reply #6 on: October 15, 2007 - 11:58:29 AM »
You may be new but please remember;posi is a GM term, Sure Grip is Mopar. :thumbsup:
Offline trouble
Re: posi fluid
« Reply #7 on: October 16, 2007 - 05:25:29 PM »
This is what I used Last year for my 410 dana.
It was recommended by someone here.
Re: posi fluid
« Reply #8 on: October 16, 2007 - 07:46:15 PM »
You hang out on moparts a bunch?   They push that sure grip **** over there.   If you had a 742 unit , odds are you had a powerlock not a cone sure grip.  Or a dana 60 with a powerlock. In the 70's when we were looking for a new chunk with bigger gears everyone no matter what you drove was looking for a posi (positive traction unit)   I think some people get offended and shy away from certain posts when people get so picky.  I'm not trying to come down on anyone, just asking some to lighten up a bit.
