Author Topic: Fuel line from pump to carb  (Read 1491 times)
Offline R/T
  • Johnson City TN
« on: October 14, 2007 - 07:19:38 PM »
I am trying to find a fuel line that runs from the fuel pump to the carb .Engine is a 440  I have tried all of the online sources but have come up empty so far.I am also wanting to get something that mates up better than a rubber hose. see pic below as this is what feeds the carb. Any suggestions? Also I really don't like the rubber line being so close to the distributor.
I was starting the car today and my brother in law stopped me and said that the fuel was leaking . I checked and had two leaks very close to the distributor.
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
moparniac
Re: Fuel line from pump to carb
« Reply #1 on: October 14, 2007 - 07:21:07 PM »
cant go wrong with real braided line...
« Last Edit: October 14, 2007 - 07:23:11 PM by moparniac »
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: October 14, 2007 - 07:24:15 PM »
In-line seems to show it:
http://www.inlinetube.com/
Kurt - SE Michigan
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: October 14, 2007 - 08:06:01 PM »
Try JEGS.  Go to the carb. inlets.  They have nice stuff,not too pricey.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline matt63
« Reply #4 on: October 14, 2007 - 09:44:31 PM »
You have at least two choices.  With the  last car I built I bent up some 3/8" steel tubing and flared the ends. I believe the fittings were Goodrich.  You can buy the repro tubing but have to use clamped rubber pieces at the filter and pump.  It's for a stock job.  For the Cuda, I used steel braided line as mentioned below.  You have to buy the ends and cut the hose.  It's a fiddly job getting the ends on but it looks the best IMHO.  Here's a pic of the braided hose on the Cuda although things have changed a little with an electric fuel pump and alternator and rad upgrade this summer.
Matt in Edmonton
'68 Valiant
« Reply #5 on: October 15, 2007 - 03:14:23 AM »
I have used the Holley Dual feed line , it has a flare end on it so you can just run steel line right into the dual feed line , it is also short enough that you can bend it slightly & get around the dist easily
