Author Topic: Why is it backfiring?  (Read 926 times)
Offline jeryst
« on: October 14, 2007 - 11:39:46 PM »
I was driving my 73 Challenger today, and it started doing something that it never did before. It ran great for a while, then, every time I would let off the throttle, it would backfire through the exhaust. Didn't seem to run bad. I stopped, and it idled fine, shut off and started fine. Got back on the road, and it still backfired every time I let off. I was close to home, so I just put it in the garage.
Anyone have any idea why it would do that?
Offline 360 'CUDA
Re: Why is it backfiring?
« Reply #1 on: October 15, 2007 - 12:59:45 AM »
Timing too far advanced?   :dunno:
Streching timing chain or loose/broken distributor, camshaft gear ect
Bent valve/pushrod/wiped camlobe/ lifter
Hard to say
« Reply #2 on: October 15, 2007 - 03:20:52 AM »
usually it will be a leak in the exhuast system allowing air into the pipes & causing combusion with the rich mix as you let off the throttle
Offline loco340cuda
« Reply #3 on: October 15, 2007 - 10:41:17 AM »
This could be caused by a few different problems as mentioned already.
I have had the same problem that you mentioned when the header burned the spark plug wire and it was arching from the header to the spark plug wire.  If you have headers this would be one more thing to check for.
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
« Reply #4 on: October 15, 2007 - 03:21:01 PM »
I've had that happen, but it was more of a miss than a backfire in my case.
I really have no other suggestions here.  :clueless:
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #5 on: October 16, 2007 - 01:01:40 PM »
a bad spark plug or bad plug wires
Offline RusTy/SE
  • Just havin' fun
« Reply #6 on: October 16, 2007 - 01:33:36 PM »
Same thing happened to me years ago on my first Challenger and it turned out to be a burnt valve.
Russ
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
