Author Topic: Headlamps??  (Read 1667 times)
Offline 71fish
  • Bless you..
    • Ken's 71fish
Headlamps??
« on: October 15, 2007 - 07:34:50 AM »
I'd like to replace all 4 headlamps in my 71 cuda. Where have you folks replaced yours from?? Napa? Online?? pricees??
Mine still work, but are not that bright anymore.. and it's not the alternator.. just time to replace. Thanks for all responses.
71fish
71fish - Nobody better than an E-BODY!!
Offline Aussie Challenger
Re: Headlamps??
« Reply #1 on: October 15, 2007 - 09:17:56 AM »
  Before you remove the old headlamps, check all the earths from the headlights to the body. Also make sure that the battery has a good earth strap to the body.   :thumbsup:
  Then as the headlight switch and dipper switch are probably 30 years old fit a couple of relays near the front of the vehicle and splice into the original wiring, or, if as I have found on some older cars I have had to replace the wiring from the relay to the headlights. Use a heavier guage wire than standard so there will be no curent drop if you decide to use more powerful wattage globes. These relays will take all the load off of the above switches and you should see a big improvement in the beam quality.   :2thumbs:
  Then you can decide what type of headlight you want to fit. I have fitted H4 Halogen semi sealed beams with the new Blue Globes which give a white light similar to the Xenon lights. A 55watt globe gives the same brightness as a 100watt with the less current draw of the 55watt globe. There are brighter globes available but my guess Napa would be a first stop. When I am in America I have found them to be the most helpful and usually at a fair price.  :money:
  David
Re: Headlamps??
« Reply #2 on: October 15, 2007 - 12:17:38 PM »
I would check ground as suggested & install relays , generally I use New Halogen seled beams from your local parts store , they arefar brighter than original incandescent
Offline 71fish
  • Bless you..
    • Ken's 71fish
Re: Headlamps??
« Reply #3 on: October 15, 2007 - 01:38:25 PM »
Thanks guys! Much appreciated
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
Re: Headlamps??
« Reply #4 on: October 15, 2007 - 01:49:47 PM »
Do I check ground, or earth?  Just curious, 'cause the earth under my 'Cuda is pretty solid.  :)
Just messin' with the aussie's!  lol
Jeff
Re: Headlamps??
« Reply #5 on: October 15, 2007 - 03:09:30 PM »
Bulbs don't get weak. It's all about power and ground. Several people have put relays in their system to help, but I haven't gotten to that point yet.
« Last Edit: October 15, 2007 - 03:42:06 PM by MEK-Dangerfield »
Offline cowboy
  • Denmark
    • CowboyCars.dk
Re: Headlamps??
« Reply #6 on: October 15, 2007 - 03:16:20 PM »
Jeff
You meen, it could be coursed by an "Earthquake"... ???                          :smilielol:
Offline cudagirl4406pk
    • Garageartmusclecars
Re: Headlamps??
« Reply #7 on: October 15, 2007 - 04:33:40 PM »
71 fish,
Kenny put the 5 3/4 tri bars lights in my cuda 100watts per light omg it is like driving with spotlights they ran 150.00 and you can get them on ebay thru fatrodder.I had the same problem and i can tell you this well worth the money.Any questions call kenny or email him.
michele
Re: Headlamps??
« Reply #8 on: October 16, 2007 - 01:24:56 AM »
I generally upgrade to relays to protect the hard to replace headlight switch
Offline 71fish
  • Bless you..
    • Ken's 71fish
Re: Headlamps??
« Reply #9 on: October 16, 2007 - 07:03:08 AM »
Michelle  -"spotlights" is what I'm looking for  lol I'll check it out. Also, will look into the relay. I don't want to blow the switch for sure.
-71fish
Re: Headlamps??
« Reply #10 on: October 16, 2007 - 07:04:43 AM »
  Just adding to my comments further up this posting.   :thumbsup:
  I found that I left the headlights on a couple of times when I parked my Challenger,  :22yikes:  so I have also installed a relay to turn them off when my ignition is turned off.
  I am still able to turn the park lights on however with the ignition off if needed.
Offline 71fish
  • Bless you..
    • Ken's 71fish
Re: Headlamps??
« Reply #11 on: October 16, 2007 - 02:09:10 PM »
.'nother good idea. Thanks
Re: Headlamps??
« Reply #12 on: October 16, 2007 - 02:49:05 PM »
np ken.just go on ebay and put in 5 3/4 headlites.The seller is fatrodder.I did not use a relay on my car and had no problems but might be a good and safe idea i will have to tell kenny.
michele
Offline Lunchbox
Re: Headlamps??
« Reply #13 on: October 16, 2007 - 06:08:10 PM »
Where do you mount them? How many do you need?
Lunch
Re: Headlamps??
« Reply #14 on: October 16, 2007 - 07:35:17 PM »
Lunch
Goody has the wiring covered on his website...as far as where I would think the radiator support would be convenient. http://www.goodysgotacuda.com/Headlights.html
