Author Topic: Starter  (Read 1212 times)
Offline trouble
Starter
« on: October 15, 2007 - 06:16:03 PM »
How do you check your starter to see if It's bad?
At times my starter spins,other times it clicks.
I turn the ignition off,then try again and it starts.
If it is the starter do I have this one rebuilt,or do I buy another one.
nivvy
Re: Starter
« Reply #1 on: October 15, 2007 - 06:21:19 PM »
Your battery may be low.......and the relay may be going as well....
Offline GoodysGotaCuda
Re: Starter
« Reply #2 on: October 15, 2007 - 06:31:56 PM »
Low battery charge, i wouldn't guess the relay quite yet. but possible. Loose battery connections, loose connections at the starter, or a bad starter solenoid that has pitting on the disc (which rotates). It could not bite, then rotate, then bite when you light the key again.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 73Chally
Re: Starter
« Reply #3 on: October 15, 2007 - 06:39:09 PM »
The clicking would make me guess low battery.  When it does turn over is it really slow, or does it turn over like you would normally expect it to?  As far as testing a starter, I had one acting up so I pulled it out and took it to AutoZone, where it turned out it was bad.  A re manufactured one was around $50 I believe  (this was about 8 years ago, though).  As far as testing one while still in the car, I don't know if that is possible or not.
Re: Starter
« Reply #4 on: October 15, 2007 - 06:45:54 PM »
I think it's your starter. You can go with the mini-starter. Do you have headers? The clicking maybe the starter relay doing it's job, just the starter won't do it's thing. Been there, done that.  :pullinghair:
Offline trouble
Re: Starter
« Reply #5 on: October 15, 2007 - 06:55:47 PM »
No headers.
If the starter spins would it be the starter?
Offline 73Chally
Re: Starter
« Reply #6 on: October 15, 2007 - 07:04:52 PM »
No headers.
When mine went bad it did spin, but what happened was the starter gear had sheared the pin that locked it to the shaft, so the shaft would turn but the gear did not.  It sounded like a real fast wirrrring (?) sound, for lack of a better term.  It did not turn the motor over at all.
Offline trouble
Re: Starter
« Reply #7 on: October 15, 2007 - 09:02:00 PM »
Is there a place where I can buy the original looking  starters?
I have a 70 440 6 pack.
Offline 422STROKER
  • Member Since 6/3/06
Re: Starter
« Reply #8 on: October 15, 2007 - 09:15:07 PM »
I bought a starter at Autozone last week and it had the pentastar on it.  45bucks
Tom :bigsmile:
Tom
Offline vinb
Re: Starter
« Reply #9 on: October 15, 2007 - 10:06:39 PM »
Hi Al, it could possibly be the armiture in the starter (dead spot). I think Rayelco Alt/Starter Rebuilders are still in Lodi on main street, they could rebuild your original one. They did all my  starters & alternators when I live up there.
Maybe I'll see you Sunday at the Fair Lawn show...
Re: Starter
« Reply #10 on: October 16, 2007 - 01:23:14 AM »
usually it si the contact ring inside the starer , the click is the electro magnet inside pushing out the drive & pulling the contact ring in , if the contacts are burned it will not turn , often a few trys will get it to start , soi yes it is the starter , if the battery was low it will do the same thing but will not have enough power to turn it over when the ring connects no matter how many times you try
Offline Robb
Re: Starter
« Reply #11 on: October 16, 2007 - 01:41:57 AM »
if it is the contacts, it will just keep doing this, being annoying and unpredictable...   until finally it wont start no matter times you turn the key.
  :iagree: Autozone for a rebuilt one
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline trouble
Re: Starter
« Reply #12 on: October 16, 2007 - 02:32:39 AM »
Vin,they are still there in lodi.
I'm going to pull it out and see if they can rebuild It.
Thank you all,and vin I will stop by on Sunday.
