Author Topic: 727 question  (Read 3346 times)
Offline Pistol Gripper
727 question
« on: January 17, 2004 - 06:15:37 AM »
Just got my 360 home last night ( bought a spare )  and it has a 727 Auto on the back of it.  It supposedly came out of a late 70's or so Van.  First off, is it usable in an E-Body.  I'll get the numbers off it if there's a chance. ( Too dark right now )  ;)
Thanks,
P.G.
O ne
B ig
A $$
M istake
A merica
Offline 360 'CUDA
Re:727 question
« Reply #1 on: January 17, 2004 - 11:18:36 AM »
Sounds like a good buy..  How much did you pay?
Those 360s are cheap horsepower and they all have
the good rods and useable heads...
Is there some sort of funky tailshaft on that 727?
that's the only part I can think of that might be
different on a van.
« Last Edit: January 17, 2004 - 11:21:06 AM by 360cuda »
Re:727 question
« Reply #2 on: January 17, 2004 - 12:44:15 PM »
The Van 833 bolts right in so I believe the 727 will also
Re:727 question
« Reply #3 on: January 17, 2004 - 12:48:42 PM »
The tailshaft on the 727 is long and thin, looks about the same length overall as a long tailshaft 833 & bellhousing.
I got the 360 & 727 pretty cheap, I'll probably sell the 727 to get some money to start rebuilding the 360.
P.G.
If the freezing rain ever quits, I'll get some numbers.
O ne
B ig
A $$
M istake
A merica
Offline DodgeFreak
  • Cars and trucks are my friends..
Re:727 question
« Reply #4 on: January 17, 2004 - 05:04:41 PM »
hey pg where you located?? i MIGHT be interested in the 727....but not sure...thanks
EDIT: i hit enter too soon.......you could mesure from the tail shaft to the bell housing on the orginal tranny and that tranny to see if theres any differences.......
« Last Edit: January 17, 2004 - 05:05:50 PM by DodgeFreak »
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Re:727 question
« Reply #5 on: January 18, 2004 - 09:02:34 AM »
DodgeFreak,
I'm near Dayton, OH.
I'll measure the 727 and compare it to the 833 & bellhousing.  My Challenger has a 904, so that's no help.  Not gonna swap the 727 in cause the Challenger deserves an 833 OD  ;D.
P.G.
O ne
B ig
A $$
M istake
A merica
Offline heminut
Re:727 question
« Reply #6 on: January 19, 2004 - 09:57:47 AM »
There are no differences between the van and car Torqueflites dimensionwise. The van 727 MIGHT have a 4 clutch front drum setup, as opposed to the 3 clutch setup found in a lot of the car 727s.
1970 5.7 Hemi Cuda
Re:727 question
« Reply #7 on: January 19, 2004 - 11:29:13 AM »
392heminut,
Would that be a good thing ?  I don't mind sounding ignorant when it comes to automatics, all I've ever really owned is 3 & 4 speeds ( other than my Chebbie Van ).  ;D
P.G.
O ne
B ig
A $$
M istake
A merica
Offline heminut
Re:727 question
« Reply #8 on: January 20, 2004 - 08:31:50 AM »
An extra clutch never hurts! The hemi 727s had 5 clutches.
1970 5.7 Hemi Cuda
Offline Carlwalski
Re:727 question
« Reply #9 on: January 20, 2004 - 12:50:02 PM »
What's the code for a HEMI 727????  ??? How can you tell, so there's 3 727's?
# Standard Duty 727 D31
# Heavy Duty 727 D32
# HEMI 727 ***?
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline keith
  • i want a new drug ...
Re:727 question
« Reply #10 on: January 21, 2004 - 11:04:28 AM »
holy crap?!? is this true? am i dreaming? can i replace my 3 spd 727 trqflite with a 4 spd 727? or even a 5 spd?? (doubt i'll ever find a 5 spd though)
you will have made my year if this is true.
are the 4 spd 727's 'weaker' than the 3 spd's or anything?
1973 Dodge Challenger
69' 383bb + holley 750 dbl pmpr
727 tran + b&m pro-ratchet
8-3/4 + auburn6 posi + 3.91
black cuda interior mod
Re:727 question
« Reply #11 on: January 22, 2004 - 04:44:12 AM »
keith,
I think you're confusing # of clutches with the # of gears ( speeds ).  A 5 clutch 727 still only has 3 forward speeds.  :'(  Just a lot stronger.
P.G.
O ne
B ig
A $$
M istake
A merica
Offline keith
Re:727 question
« Reply #12 on: January 22, 2004 - 06:50:29 AM »
doh!
some day i'll learn to take the time to 'read' the posts.
Offline DodgeFreak
Re:727 question
« Reply #13 on: January 22, 2004 - 09:51:51 PM »
Ok........when keith said 5 spd this got me thinking...........Gearvendors........how does that work is it internal or external like the klunv things for 4X4s that go between the Tcase and Trans....If the Gearvendors is internal could you put one in a 518 that would add a 4th gear and then you could have your OD??  Depending on the 4th gear ratio the GV adds...that would be cool....5spd auto hummmmmmmmmm....just a thought???  :-\ :'(
04 durango 4.7
Re:727 question
« Reply #14 on: January 22, 2004 - 10:16:29 PM »
The GV unit is an add on , you remove the extension housing & it couples with the output shaft
