Author Topic: power window issue - window goes down but not up  (Read 792 times)
Offline Robb
« on: October 16, 2007 - 01:36:44 AM »
So my passenger side rear quarter window is having issues.
it will go down but does not respond to the switches on the Driver side or at the switch for the window itself.   I pulled the motor and tested it and it works fine, I reinstalled it and ran a battery direct to the motor and it worked fine, window went up.  I Took a test light, and at the switch by the back window, it gives energy in the down position, but not in the up position.
I am assuming that by the wiring diagrams that if it was the power window relay at risk, either it would work, or not work at all ?    Relay looks super simple  12v in 12 volt out, and a 12 switched power.    Also Other windows go up and down OK.
 but what would cause both switches to function the same  (wtih no ups, just downs ?)   on the same window ?
 :clueless: :clueless:
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Re: power window issue - window goes down but not up
« Reply #1 on: October 16, 2007 - 01:53:34 AM »
bad contacts in both switches, take them apart & clean the contacts
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #2 on: October 16, 2007 - 08:54:32 AM »
 :iagree: :iagree:
