Author Topic: 400 Backfiring  (Read 1615 times)
Offline bordin34
400 Backfiring
« on: October 16, 2007 - 07:45:38 PM »
My 73 400 is backfiring. What would cause this and how can I fix this. It also sputters and stumbled from about 1500-1800rpm, I am guessing because I do not have a tach. Could it be running too lean? The carb is a 670cfm holley street avenger and it has a mild cam and headers. It isn't just pop backfiring, it is who shot a gun backfiring.
Dan
« Last Edit: October 16, 2007 - 08:44:35 PM by bordin34 »
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Re: 400 Backfiring
« Reply #1 on: October 16, 2007 - 11:10:54 PM »
usually it is a leak in the exhaust , but it could be a problem with the power valve leaking or not enough vacuum to keep it closed
 is the carb new ?
Offline bordin34
Re: 400 Backfiring
« Reply #2 on: October 17, 2007 - 02:59:45 PM »
I think the carb is a couple years old. I also think that the header to exhaust gasket is leaking. Would that cause a backfire.
Re: 400 Backfiring
« Reply #3 on: October 17, 2007 - 05:21:06 PM »
any leak in the exhuast can draw in air & cause combustion inside the exhaust
Re: 400 Backfiring
« Reply #4 on: October 17, 2007 - 05:39:34 PM »
Is this a new problem? Do your spark plugs look white, like they are way lean? I find it interesting that this just happens at a certain RPM range.  :screwy: Does it happen under throttle, or while coasting?
Offline bordin34
Re: 400 Backfiring
« Reply #5 on: October 17, 2007 - 05:43:14 PM »
It backfires from idle to high rpms. It sputters from 1500-1800.
Re: 400 Backfiring
« Reply #6 on: October 17, 2007 - 05:51:15 PM »
From this, I'll guess multiple demons at work here. Chryco was probably right about the exhaust thing. I would think the leak would need to be huge to cause that though.  :dunno: Your sputtering is probably a carb problem. Have you messed with it at all? Meaning, do the plugs look good? Maybe the secondaries are opening too fast or too slow? Have you tried different springs in there(lighter, or heavier)?
Offline bordin34
Re: 400 Backfiring
« Reply #7 on: October 17, 2007 - 07:23:25 PM »
I have done nothing with the car. All I have done is let it idle up to temp and drive it about 600ft. a couple times. I have not opened the secondaries or gone above 30mph. But when I give it more gas like enough to make it downshift if it were in 2nd gear, it wants to stall and sometimes does.
Offline vinb
Re: 400 Backfiring
« Reply #8 on: October 17, 2007 - 07:46:49 PM »
Hey bordin34, I'll be up in Fair Lawn on River Road Sunday the 21st for a car show if doesn't rain. If you bring it over I'll  be more than happy to look at it for you. I will be parked near Berdan Ave on River Road by the Dunkin Donuts. Just look for my Cuda. Trouble said he will stop by, but I think without his Cuda..
Offline bordin34
Re: 400 Backfiring
« Reply #9 on: October 17, 2007 - 07:54:13 PM »
Won't be around saturday, thanks for the offer anyway.
Offline bordin34
Re: 400 Backfiring
« Reply #10 on: October 17, 2007 - 09:45:47 PM »
Anyway, here is a picture of the car.
And a video of it revving, not backfiring in it.
