Author Topic: hemi bolts/ studs  (Read 807 times)
Offline BIG MIKE
hemi bolts/ studs
« on: October 18, 2007 - 11:34:09 PM »
can you get the heads off if you have studs in the car .... i don't think there is room the lift them off that high..
Offline 4Cruizn
  • HEMI FISH
Re: hemi bolts/ studs
« Reply #1 on: October 18, 2007 - 11:40:17 PM »
 :clueless: I don't know for sure but I thought I heard that you can't.   :dunno:   That would suck though . .
« Reply #2 on: October 18, 2007 - 11:57:32 PM »
The studs I believe are just snug not tq'ed as I recall, and can be unscrewed and removed easy enough.
« Reply #3 on: October 19, 2007 - 12:31:18 AM »
you will not get heads off with studs in the car , unlike GM the studs are dry so removing them is not too bad , gms have to be tread sealed into place to keep water out
Offline quagmire
  • Traction Impaired......
« Reply #4 on: October 19, 2007 - 01:25:08 AM »
ARP head studs have an allen keyway machined into them so you can remove them in the car.
