Author Topic: hood pin locations  (Read 996 times)
sleepychallenger
hood pin locations
« on: October 19, 2007 - 10:52:34 AM »
i was wondering if anyone had pics of the hood pin locations for both the front and rear pins for a lift off hood? Just wondering how it is done in case i decide to go this way.
Re: hood pin locations
« Reply #1 on: October 19, 2007 - 11:25:39 AM »
the front pins are easy to locate , the hole is already int the body & you can see the hole in the inner hood frame , the rear is totally up to you they never had a lift of hood so you need to make brackets & holes
sleepychallenger
« Reply #2 on: October 19, 2007 - 11:45:38 AM »
has anyone done this and do you have pics?
Offline 73440cuda
« Reply #3 on: October 19, 2007 - 01:31:48 PM »
For the back I just took a piece of steel about 1"w x 6"L and bent it into a L shape, drilled a hole in the top for a pin, marked and drilled two holes in the side for where the hood hinge was and bolted it in place..
sleepychallenger
« Reply #4 on: October 19, 2007 - 01:56:18 PM »
can you post some pics please, i was hoping to do something without drilling, i think i might have to get creative with this one
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #5 on: October 19, 2007 - 07:39:29 PM »
i`ll have to get some pics of mine,it`s a cuda but should give you some ideas for yours.I made a bracket that uses the 3 hood hinge bolt holes and places the pin in line with the fronts side to side and above the cowl as I thought having them directly above the hinge location was too far forward and did not look very good.You can see how far back they are in these pics but I don`t have any of the brackets yet.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline farmboy70
« Reply #6 on: October 20, 2007 - 08:29:51 AM »
Here are some pictures of pin brackets we made to put a lift of hood on a Swinger.These bolt into the hood hinge bolts so they can be removed and the hinges put back on later if he wanted to go back to a stock hood.
sleepychallenger
« Reply #7 on: October 21, 2007 - 12:15:41 AM »
thanks dave, thats what im looking for
sleepychallenger
« Reply #8 on: October 21, 2007 - 10:44:56 AM »
what are the rubber bumpers on there?
Offline farmboy70
« Reply #9 on: October 21, 2007 - 03:16:08 PM »
Those were used to set the height of the pin and were later thrown away.
sleepychallenger
« Reply #10 on: October 21, 2007 - 06:17:33 PM »
right on, thanks for the info and pics. if anyone has any other pics please post them, i think i might go with the 4 pin lift off hood
