Author Topic: Need pics. of 17" rims with more rubber..  (Read 1869 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: October 20, 2007 - 05:05:46 AM »
I got these 17" wheels, and want to try'em out on the Challenger, but think the tires looks like rubberbands on them.
It's 7" with 215 - 50, - and 8" with 245 - 45 on'em...
Anyone got pics. of 17" rims with wider, and higher tires..???
DeSoto is gonna get some wire-wheels...
Offline GoodysGotaCuda
Re: Need pics. of 17" rims with more rubber..
« Reply #1 on: October 20, 2007 - 08:14:05 AM »
18s on the back, but 295/45/18s, 28.5" tall
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: October 20, 2007 - 11:02:16 AM »
You know your car looks great, - but - Still like rubberbands...   :clueless:
« Reply #3 on: October 20, 2007 - 03:29:45 PM »
How much tire do you want? they have more height than 275/60/15s.... unless you start going to truck tires, thats about it lol. Next up is usually 29.5 or 30" tall tires. The sidewall is there, and this car has super stock springs. with stockers they would rub on the outsides of the wheel wells...
These are rubber bands my friend :bigsmile:
1976 Dodge Warlock
Offline IMNCARN82
  • LeDZeP
« Reply #4 on: October 20, 2007 - 05:28:22 PM »
17x8 4.5 bs F  17x9 5.0 bs R       245/45/17 F  275/40/17 R
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #5 on: October 20, 2007 - 06:08:12 PM »
GoodysGotaCuda - I really like your set up.. Coool car... :thumbsup:
But I wanna keep mine LoooW - with no rubbing no where....
I was thinking, - something like - 255/60 or 265/55-17,  or..???  How do that look ..???
« Reply #6 on: October 20, 2007 - 06:47:43 PM »
that may fit, depends on the wheel backspacing. They are just as tall as the tires im running on the back. What backspacing?
1976 Dodge Warlock
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #7 on: October 20, 2007 - 06:53:14 PM »
Not absolutly sure,  but I think 4,5" - maybe only 4"..
Rigth now, I'm on 245 / 60 - 15, want them just a tinny bit higher..???
« Last Edit: October 20, 2007 - 06:55:24 PM by cowboy »
« Reply #8 on: October 20, 2007 - 06:59:01 PM »
Well that puts them out closer 1/4 lip, more likely to rub. Remember i have super stock springs, same height tires, 6" backspacing and my wheels have rubbed once at the back of the well....just keep that in mind.
1976 Dodge Warlock
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #9 on: October 20, 2007 - 07:00:35 PM »
Rigth, - but mine is only 8" wide..???
« Reply #10 on: October 20, 2007 - 07:16:16 PM »
Here is a direct comparison. go here
http://www.rims-n-tires.com/rt_specs.jsp
on the left do, 295, 45, 18   on 18 x 9, +24offset.       for you, do 265/55/17 17x8, 0offset (4.5") or -12offset (4")
On the 4" backspacing compared to my wheels. It says "Package will stick out 21 mm (0.8'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset."
On the 4" backspacing it says "Package will stick out 9 mm (0.4'') farther. Acceptable for most cars. "
So yes i run wider tire and wider rim. However your wheels will stick out twords the 1/4 lip .8" or .4" further. On my car i dont have that much room to play on. I'm not trying to get you to comment on my setup or what have you, i appriciate it...but, my point has been to look at what i have and compare before you buy something that wont fit.... Another point is that it will change where your rubbing issue may be, it may clear sitting still, but as the suspension travels it might rub further down the well. Take a look at the picture i posted, if i hit a h-a-r-d bump, ill get a rubber streak here...
« Last Edit: October 20, 2007 - 07:21:38 PM by GoodysGotaCuda »
1976 Dodge Warlock
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #11 on: October 20, 2007 - 07:30:36 PM »
Got it, gonna check real carefull...
 :thumbsup:
« Last Edit: October 21, 2007 - 06:38:01 AM by cowboy »
Offline 74 340 4speed
« Reply #12 on: October 25, 2007 - 10:27:16 PM »
My 1999 Camaro SS.
17x9.5 up front, 275/45/17
17x11 out back. 315/35/17
It will be pretty hard to find a tall side wall for a 17" rim in a performance oriented tire.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
« Reply #13 on: October 26, 2007 - 07:04:01 AM »
You can find 45, 50 and 55 profile tires in 17" diameters, but you have to look at the truck applications to find them, and they are going to be around 30-32 inches tall
Offline Blackcuda
« Reply #14 on: October 26, 2007 - 11:08:39 AM »
My Cuda on 17's with big meat on the rear.
