Author Topic: Removing LCAs from Challenger - need help. Got Them Off.  (Read 1323 times)
Offline 70challrtse
« on: October 20, 2007 - 08:02:44 PM »
Will someone please post easy to follow instructions, for the mechanically challenged, on removing  LCAs from a 70 Challenger. Thanks.
« Last Edit: October 28, 2007 - 01:06:44 PM by 70challrtse »
Re: Removing LCAs from Challenger - need help.
« Reply #1 on: October 21, 2007 - 02:36:46 AM »
-Jack up car , remove wheel
- remove brake caliper & rotor if disc , remove drum if not
- undo the shock lower bolt
- undo the nut [3/4"] on rear of caster strut
- remove clip from rear of torsion bar
- undo T bar adjuster [3/4" bolt]
- remove 15/16" nut from LCA pivot pin
- undo the 2 15/16" bolts through spindle into lower ball joint
- pry between LCA & K frame to push T bar & LCA out of K frame
Offline 70challrtse
« Reply #2 on: October 21, 2007 - 08:44:45 AM »
Thanks.
Offline wally426ci
    • maryland mopars
« Reply #3 on: October 21, 2007 - 11:23:55 AM »
yeah, you can squeeze the torsion bar clip with the 2 pins pointing at you. torsion bars that have never been out can be a pain, may need to coax it out with a hammer, but be sure to protect it from mushrooming the torsion bar. ever try putting a round peg in a square hole?
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 70challrtse
« Reply #4 on: October 28, 2007 - 01:03:52 PM »
Thanks for the info, with the help of my friend we got the LCAs off and cleaned up. We recoated them with cosmoline as they came from the factory.
Offline 70challrtse
Re: Removing LCAs from Challenger - need help. Got Them Off.
« Reply #5 on: October 28, 2007 - 01:08:06 PM »
Here's another pic, hope it shows more.
« Reply #6 on: October 29, 2007 - 12:33:08 AM »
 :2thumbs:
Offline LAA66
« Reply #7 on: October 29, 2007 - 09:45:28 AM »
 Look's really nice. :grinyes: So how was the rebuild, any tips? That's my next project along with the steering box.
Offline 70challrtse
« Reply #8 on: October 29, 2007 - 10:20:51 AM »
Took my friend and I about 5-6 hours to take it apart and put back together, and another 4-5 hours to do the clean up and resto work.
